Suddenly it won’t let me edit or delete the default lists. In fact I was able to create a task at the beginning but after creating a new list the others were disabled, since it does not allow me to modify or eliminate them. I already removed and reinstalled the application but that did not restart the previously scheduled tasks. What I can do?
Hi, as you might see are those lists from the Deck app. You should be able to hide them in the settings of the Deck app.
Thank you very much for the help. It is true, it was a matter of deck, not task
Its a Case closed
