Hello
We have installed talked server repo on our same nextcloud server (Latest Version of Nextcloud) by following procedure
And installed the talked client from app store. Registered the commands as:
sudo -u www-data php occ talk:command:add recording Talked “php /var/www/html/nextcloud/files/occ talked:record {ROOM} {ARGUMENTS}” 2 2
But when run command in chat /recording start, it says “An error occurred while running the command. Please ask an administrator to check the logs.”
Logs:
InvalidArgumentException: Chat command failed [Code: 1]: php /var/www/html/nextcloud/files/occ talked:record ‘du4jf9ty’ ‘start’
Error: Attempt to read property “message” on null at /var/www/html/nextcloud/files/apps/talked/lib/Command/Record.php#204
Please suggest simple procedure of Talked.
Thanks
just
March 13, 2022, 9:35pm
#2
Did you check the documentation?
Says only public calls with guests allowed may be recorded, among other limitations.
Can you plz explain what is meant by public calls with guest?
I am trying to call recording between the users which exist in my nextcloud.
Hi
I have created new conversation and invited nextcloud user as a guest via link, then enter the command in conversation /recording start. It gives same error
Logs:
Please help to resolve the issue
Thanks
just
March 14, 2022, 1:22pm
#5
You should try asking the developer directly. File an issue on their github repo and send them your logs so they can actually respond and help you out. Good luck.
Re-check all of the setup steps, because there are way more than you mention in your post. Never heard anyone discuss this app before on the forum, but it is clearly super complicated and in early development…
I have opened issue in github, waiting for response.
If someone else experienced this app, let me know plz
thanks
So here is the solution, it may help someone
opened 03:54PM - 15 Mar 22 UTC
closed 11:53AM - 25 Mar 22 UTC
Hello
We have installed talked server on our same nextcloud server (Latest Ve… rsion of Nextcloud) by following procedure
Nextcloud is running through apache without docker.
https://github.com/MetaProvide/talked
Created conversation and invited nextcloud user via link.
Logs:
Os: Debian 10
Thanks
@just thanks because of your reply i moved to github and posted issue, author of talked helped a lot in this
