Can anyone help me to use the Talk API either via curl or via php? I tried hard the last hours with certain api calls, but all I got was a
<?xml version="1.0"?>
<ocs>
<meta>
<status>failure</status>
<statuscode>404</statuscode>
<message>Invalid query, please check the syntax. API specifications are here: http://www.freedesktop.org/wiki/Specifications/open-collaboration-services.
</message>
</meta>
<data/>
</ocs>
I used curl i.e.:
curl -X POST -d 'newParticipant:test' -d 'source=users' -H "OCS-APIRequest: true" -v -u "<user>:<pw>" https://cloud.fra.at/ocs/v2.php/apps/spreed/api/v1/room/r8wukdy6/participants
my use case would be to add a user to an existing conversation.
Can anyone help me with that?
Thanks,
Marcus.
