How can I add custom tags to files in nextcloud?
I only found docs about automated tagging. How can I create custom tags?
Hi, can you please share the link to the documentation you mentioned? Maybe that helps a little in finding a solution …
You can create custom-tags to every file manually. Open Nextcloud in your browser, check into the files(app). There you choose your a file, click on the three dots in the same line. That gives you a context-menu. There you go to “details”. In the opened details-overview click on the three-dotted-menu (next to the close-x-button). There you go with Tags. It’s hidden, when no tags are active, but it’s showing up, when the file has at least one tag.
