example
longer
example
here
Nextcloud version _ 20.0.8_
Operating system and version _Raspberry Pi OS
Apache or nginx version NGinX 1.41
PHP version 7.3
I was running the automatic updater to 20.0.9. It crashed at step 9. When I tried to reload the page just said “update in process”. I checked the manual and tried:
sudo -u www-data php /var/www/nextcloud/updater/updater.phar
but when it asks me ‘should the occ upgrade command be executed?’ it fails:
Nextcloud is not installed - only a limited number of commands are available
And now when I go to log on I get the new install page and the config file has been wiped. I still have backed up files in the /data/updater… directory
What do I need to do to get it working again?
Thanks in advance
