Operating system and version: Lubuntu17.10 (post-upgrade)
The issue you are facing: System Tray Icon not appearing after upgrading lubuntu from 16.10 to 17.10
- Client runs fine on 16.10
- Upgrade to 17.10 through live-USB (not while running lubuntu locally)
- Reinstall nextcloud client (old config files still in place after upgrade)
- Nextcloud tray icon shows missing icon image instead of current server status
The output of your Nextcloud log in Admin > Logging: Doubt this is needed, works on other machines
Not sure where to find
Too many files in there, none of which are related to Apache/nginx which one do you need?
