After update to v20 I wanted to check my apps status.
The request times out.
This is in the logs:
{"reqId":"...","level":2,"time":"2020-10-11T11:07:10+00:00","remoteAddr":"172.25.0.4","user":"..." ,"app":"appstoreFetcher","method":"GET","url":"/settings/admin/serverinfo" ,"message":"Could not connect to appstore: cURL error 28: Connection timed out after 60001 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html)"
Version: 20.0.0.9
I would like to suggest to not access the app store synchronously which blocks page load. I suggest to have an asynchronous request instead and fail gracefully if the request should fail.
Yes, https://apps.nextcloud.com/ is down. But that should not prevent me from seeing my installed apps IMHO.
Is there an issue for that already? Should I open one?
