System config option "blacklisted_files" is deprecated and will be removed in Nextcloud 34, use "forbidden_filenames" instead.
after upgrade to 30.x
Nextcloud Server Administration Manual, Release latest
Nextcloud configuration
Changes to the available options in config.php.
• The option blacklisted_files is now deprecated and replaced with forbidden_filenames
https://docs.nextcloud.com/server/latest/Nextcloud_Server_Administration_Manual.pdf - page 4 and 104.
GL
Hi @romarioZ1000
If there is a question hidden in your post, I couldn’t find it… :wink:
Just in case your post was meant as a question, and that question was what to do, then my answer would be to change the configuration parameter blacklisted_files to forbidden_filenames in the config.php.
