On my desktop I can’t set some files at the “Free up space” status.
Nextcloud version
- client : 3.5.2
- server : 24.0.3
Operating system and version
- client : windows 10.0.19044
- server : Debian 11
Apache : Apache/2.4.54 (Debian)
PHP version : PHP 8.1.8 (cli) (built: Jul 11 2022 08:55:24) (NTS)
The issue you are facing : I have to keep some files on my desktop because they can’t be “Free up”
Steps to replicate it :
I don’t know actually how to create the problem
But, if I take a problematic file and copy it in a new folder, the problem remains
In the sync.log file (AppData/Roaming/Nextcloud) :
- the initial copy leaves the following trace => the file is stored on the desktop and synchronized
timestamp duration file instruction dir modtime etag size fileId status errorString http result code other size other modtime X-Request-ID
18:09:22 <file> 8 1 1659990112 5e7d27e78bcf2bd1c22a1ee0999d8adc 1682 00452258oc6lwp0up92s 4 201 0 0 b503a6c9-70ae-4072-9620-80484283c7db
- when I try to free up the space, I’ve got the following trace :
<file> 64 2 1659990112 5e7d27e78bcf2bd1c22a1ee0999d8adc 1682 00452258oc6lwp0up92s 4 0 1682 1659990112
In the owncloud.log.0 during the initial copy, I can found this message :
[ debug default C:\Users\sysadmin\AppData\Local\Temp\2\windows-10816\client-building\desktop\src\libsync\propagateupload.cpp:300 ] [ OCC::PropagateUploadFileCommon::slotComputeContentChecksum ]: Trying to compute the checksum of the file
2022-08-09 20:09:22:925 [ debug default C:\Users\sysadmin\AppData\Local\Temp\2\windows-10816\client-building\desktop\src\libsync\propagateupload.cpp:301 ] [ OCC::PropagateUploadFileCommon::slotComputeContentChecksum ]: Still trying to understand if this is the local file or the uploaded one
Is there a way to correct the problem ?
Thanks.
