Nextcloud version (eg, 20.0.5): 20.0.8 at the momemnt issue happened on previous versions too
Operating system and version (eg, Ubuntu 20.04): Debian 10
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.38
PHP version (eg, 7.4): 7.4.15
User A files dissapear from local folder after few seconds. Folder, to which the files ( .pdf .txt .gpc) are copied to is owned by a different user B and is shared to user A. User A is using his laptop with Win10 and user B is also active at the same time on Windows server 2012 R2. In the activity log of user B there is a information that the file was succesfully synchronized meaning deleted from server to trashbin. User A wanted to provide me with a video of the error so he tried reproducing it. The problem happened partialy when the file got deleted from his PC for a moment and then synchronized back from the server after a second
Is this the first time you’ve seen this error? (Y/N): No
- Setup NC server and 2 clients A and B
- Upload 55 000 files, 80GB to client B
- Share a folder to client A
- Download or copy files to the shared folder on user A computer
I can send the logs if its necessary, no errors concerning synchronization.
'instanceid' => 'xxx',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
'trusted_domains' =>.
0 => 'nextcloud.xxx.tld',
'datadirectory' => '/srv/nextcloud/data',
'trashbin_retention_obligation' => '30,90',
'version' => '20.0.8.1',
'overwrite.cli.url' => 'http://nextcloud.xxx.tld',
'dbname' => 'nextcloud',
'dbhost' => 'localhost:3306',
'dbuser' => 'oc_xxx',
'dbpassword' => 'xxx',
'ldapIgnoreNamingRules' => false,
'theme' => '',
'loglevel' => 0,
'redis' =>.
'host' => '127.0.0.1',
'port' => 6379,
no errors
