I’ve an isue with my synchronization.
Actually i have use the Nextcloud application for Ubuntu to synchronize one folder.
This folder is share with another user of my cloud.
- In this folder i have another folders.
- The synchronization on the cloud is good the folder “Schéma” is on my cloud since my Laptop
- On my laptop i copy all the files in a folder “Schémas”
- Now i have two folder “Schémas” and “Schéma”
- On my laptop i decided to delete “Schémas” but the synchronization doesn’t work
My issue :
- On my computer the folder “Schéma” is deleted
- On my cloud the folder “Schéma” is undeletable, when i refresh the webpage it appears again…
- My desktop application notify me that it can’t synchronize the folder “Schéma”
On my Nextcloud access log i had a 404 code in my log for the delete action.
On my Nextloud data-folder, in my user directory, the folder “Schéma” doesn’t exists…
My collegue a deleted the folder “Schéma” on his laptop and he hasn’t any problem with is synchronization…
If you had any idea or if you need any information.
Thank you for helping
StrangeMonkey
