Synchronisation does not work
example
longer
example
here
Nextcloud version: 3.13.0
Operating system and version: android
Is this the first time you’ve seen this error? Y
  1. Some one added a document.
  2. Later on the document is changed.
  3. I can see the updated document only if I open it via web-gui not in the nextcloud app.
