Synch with Thunderbird and nextcloud problem with double Authentifciation
I do not have synchronisation with Thunderbird and NC when I use the TOTP authentifcation on NC,
And when I disable the TOTP auth, synchor works,
Is anyone are in the same situation like me?
thank you !
If you have 2FA enabled you need to create an App Password and then use that for Thunderbird to login.
To create an app password in Nextcloud, go to…
Personal Settings → Security → Devices & sessions → Create new app password
Super, it’s resolved, thank you very much for your help !
