example
longer
example
here
Nextcloud version (eg, 29.0.5): desktop version 3.4.2 Operating system and version _(eg, Ubuntu 24.04)_:
Ubuntu 22.04 4
I am using Nextcloud desktop client from two computers with the same configuration. In one of them, most of the time I create or modify a file, it gives a sync error directly on Nextcloud. But if I close and open back the app, it works again, with everything synchronised. However, this problem doesn’t occur on the other computer with the same configuration.
Could anyone help me?
I don’t know where to find the log. There is nothing related to Nextcloud on /var/www
Cheers
- Create a new file
- Modify it a few times
- Wait
I can't find the "Admin" file
PASTE HERE
PASTE HERE
Nothing related to nextcloud in /var/www
