Nextcloud version 13.0.6 (installed through YunoHost)
Operating system and version Debian 9.5 x64 on Digital Ocean
Apache or nginx version Nginx/1.10.3
PHP version PHP 7.0.30-0+deb9u1
When using the Windows Sync Client, I get a plethora of “server replied: Internal Server Error”, “File was deleted from server”, “Service Unavailable” and "Operation Canceled"
Is this the first time you’ve seen this error? No
Steps to replicate it: Run Sync Client
Aws\S3\Exception\S3Exception: Error executing "ListObjects" on "https://dtm.sfo2.digitaloceanspaces.com/?delimiter=%2F&prefix=Resources%2FTemplates%2F&encoding-type=url"; AWS HTTP error: Server error response [url] https://dtm.sfo2.digitaloceanspaces.com/?delimiter=%2F&prefix=Resources%2FTemplates%2F&encoding-type=url [status code] 503 [reason phrase] Slow Down SlowDown (server): Please reduce your request rate. - <?xml version="1.0" encoding="UTF-8"?> <Error> <Code>SlowDown</Code> <Message>Please reduce your request rate.</Message> <RequestId></RequestId> </Error>
/var/www/nextcloud/3rdparty/aws/aws-sdk-php/src/WrappedHttpHandler.php - line 101: Aws\WrappedHttpHandler->parseError(Array, Object(GuzzleHttp\Psr7\Request), Object(Aws\Command), Array)
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 203: Aws\WrappedHttpHandler->Aws\{closure}(*** sensitive parameters replaced ***)
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 174: GuzzleHttp\Promise\Promise callHandler(2, Array, Array)
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/RejectedPromise.php - line 40: GuzzleHttp\Promise\Promise GuzzleHttp\Promise\{closure}(*** sensitive parameters replaced ***)
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/TaskQueue.php - line 47: GuzzleHttp\Promise\RejectedPromise GuzzleHttp\Promise\{closure}(*** sensitive parameters replaced ***)
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 234: GuzzleHttp\Promise\TaskQueue->run()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 267: GuzzleHttp\Promise\Promise->waitIfPending()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 225: GuzzleHttp\Promise\Promise->invokeWaitList()
/var/www/nextcloud/3rdparty/guzzlehttp/promises/src/Promise.php - line 62: GuzzleHttp\Promise\Promise->waitIfPending()
/var/www/nextcloud/3rdparty/aws/aws-sdk-php/src/AwsClientTrait.php - line 59: GuzzleHttp\Promise\Promise->wait()
/var/www/nextcloud/3rdparty/aws/aws-sdk-php/src/ResultPaginator.php - line 127: Aws\AwsClient->execute(Object(Aws\Command))
/var/www/nextcloud/apps/files_external/lib/Lib/Storage/AmazonS3.php - line 288: Aws\ResultPaginator->valid()
/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php - line 101: OCA\Files_External\Lib\Storage\AmazonS3->opendir('Resources/Templ...')
/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Availability.php - line 109: OC\Files\Storage\Wrapper\Wrapper->opendir('Resources/Templ...')
/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php - line 101: OC\Files\Storage\Wrapper\Availability->opendir('Resources/Templ...')
/var/www/nextcloud/lib/private/Files/Storage/Wrapper/Wrapper.php - line 101: OC\Files\Storage\Wrapper\Wrapper->opendir('Resources/Templ...')
/var/www/nextcloud/lib/private/Files/Cache/Scanner.php - line 375: OC\Files\Storage\Wrapper\Wrapper->opendir('Resources/Templ...')
/var/www/nextcloud/lib/private/Files/Cache/Scanner.php - line 426: OC\Files\Cache\Scanner->getNewChildren('Resources/Templ...')
/var/www/nextcloud/lib/private/Files/Cache/Scanner.php - line 406: OC\Files\Cache\Scanner->handleChildren('Resources/Templ...', false, 3, '8300665', true, 0)
/var/www/nextcloud/lib/private/Files/Cache/Scanner.php - line 338: OC\Files\Cache\Scanner->scanChildren('Resources/Templ...', false, 3, '8300665', true)
/var/www/nextcloud/lib/private/Files/View.php - line 1326: OC\Files\Cache\Scanner->scan('Resources/Templ...', false)
/var/www/nextcloud/lib/private/Files/View.php - line 1369: OC\Files\View->getCacheEntry(Object(OCA\RansomwareProtection\StorageWrapper), 'Resources/Templ...', '/DTM/Resources/...')
/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php - line 223: OC\Files\View->getFileInfo('/derek/files/DT...')
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php - line 76: OCA\DAV\Connector\Sabre\Directory->getChild('Templates')
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php - line 71: Sabre\DAV\Tree->getNodeForPath('files/derek/DTM...')
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Tree.php - line 103: Sabre\DAV\Tree->getNodeForPath('files/derek/DTM...')
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAVACL/Plugin.php - line 878: Sabre\DAV\Tree->nodeExists('files/derek/DTM...')
[internal function] Sabre\DAVACL\Plugin->beforeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105: call_user_func_array(Array, Array)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 466: Sabre\Event\EventEmitter->emit('beforeMethod', Array)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 254: Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/nextcloud/apps/dav/lib/Server.php - line 293: Sabre\DAV\Server->exec()
/var/www/nextcloud/apps/dav/appinfo/v2/remote.php - line 35: OCA\DAV\Server->exec()
/var/www/nextcloud/remote.php - line 164: require_once('/var/www/nextcl...')
{main}
'passwordsalt' => '#',
'secret' => '#',
0 => 'localhost',
1 => 'cloud.dtm-creative.com',
'datadirectory' => '/home/yunohost.app/nextcloud/data',
'overwrite.cli.url' => 'http://localhost',
'version' => '13.0.6.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'fwFRMWSrkZy3vBXCgZm2iez9',
'instanceid' => 'occ3onqxrsrv',
'ldapIgnoreNamingRules' => false,
'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
'updatechecker' => false,
'integrity.check.disabled' => true,
'redis' =>
'host' => 'localhost',
'port' => '6379',
'timeout' => '0.0',
'password' => '',
'logout_url' => 'https://core.dtm-creative.com/yunohost/sso/?action=logout',
'mail_from_address' => 'derek',
'mail_smtpmode' => 'php',
'mail_domain' => 'dtm-creative.com',
Everything appears obfuscated in the log .gz files, such as �ξ{^D^U�
Through searching these forums, I’ve attempted doing the OCC commands (which all returned positive) to repair the database and have been unable to fix this.
