Running latest NCP version on Pi 4, latest NC version, latest NC client apps on LInux and Android.
Getting sync errors on photos (from phone), .pdf files and .epub file (from Linux Mint laptop). Android app says âUnknown errorâ. Linux app says âHEADERS on invalid streamsâ.
I cannot locate any nextcloud.log or error.log files. Where are they supposed to be?
nextcloud.log default location would be /var/www/nextcloud/data/nextcloud.log,
unless you used nc-datadir to move data to another location.
You can also view nc log entries from NC admin page.
âtempdirectoryâ corrected in the config.php file
But the sync problem persists. Same files are still a problem, and Instant Upload from Android phone (OpenCamera photos) does not work (âBad requestâ).
And now the Linux desktop client says âError while loading the list of folders from the server. Unknown errorâ. Access through the web interface is fine, however.
