first of all, here the details:
Nextcloud version (eg, 12.0.2): 18.0.3
Operating system and version (eg, Ubuntu 17.04): Raspbian Buster Linux rpi4 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l GNU/Linux
Apache or nginx version (eg, Apache 2.4.25): Default NextcloudPi
NextCloudPi version | v1.24.0 |
NextCloudPi image | NextCloudPi_docker_04-06-20 |
distribution | Debian GNU/Linux 10 \n \l |
automount | no |
USB devices | sda sdb |
datadir | /data/nextcloud/data |
data in SD | yes |
data filesystem | ext2/ext3 |
data disk usage | 6.2G/29G |
rootfs usage | 6.2G/29G |
swapfile | /var/swap |
dbdir | /data/database |
Nextcloud check | ok |
Nextcloud version | 18.0.3.0 |
HTTPD service | up |
PHP service | up |
MariaDB service | up |
Redis service | up |
Postfix service | up |
internet check | ok |
port check 80 | closed |
port check 443 | closed |
IP | 172.18.0.5 |
gateway | 172.18.0.1 |
interface | eth0 |
certificates | none |
NAT loopback | no |
uptime | 6min |
PHP version (eg, 7.1): Default NextcloudPi
I have just set up a Raspberry Pi 4 with docker as my new “home server”.
It uses the latest raspian buster. I installed docker and nginx as reverse proxy. I also use NextcloudPI as docker container.
Everything works as expected, as long as my Raspberry Pi uses the WiFi network interface. Now I have installed some cables and would like to have it use the wired connection.
During configuration I made sure to always only use the hostname of the raspberry: “rpi4”. So I disabled WiFi on the RPI in “/boot/config.txt” and plugged in the ethernet cable. The nginx docker container is reachable, portainer docker container also. Also the NextcloudPi Admin Webinterface is reachable, but I can’t connect to the Nextcloud in any way (unreachable). I have no Idea where to look, but expect it to be some kind of Nextcloud configuration, but couldn’t find anything.
If I reactivate WiFi, everything works again.
Here is my docker-compose.yml
pi@rpi4:~ $ cat docker-compose.yml
version: “3”
services:
nginx-proxy-manager:
image: jc21/nginx-proxy-manager:latest
restart: unless-stopped
container_name: nginx-proxy-manager
ports:
# Public HTTP Port:
- ‘80:80’
# Public HTTPS Port:
- ‘443:443’
# Admin Web Port:
- ‘81:81’
volumes:
# Make sure this config.json file exists as per instructions above:
- /mnt/usb1/nginx-proxy-manager/config.json:/app/config/production.json
- /mnt/usb1/nginx-proxy-manager/data:/data
- /mnt/usb1/nginx-proxy-manager/letsencrypt:/etc/letsencrypt
depends_on:
- mariadb
mariadb:
image: yobasystems/alpine-mariadb:latest
container_name: mariadb
environment:
MYSQL_ROOT_PASSWORD: “xxx”
MYSQL_DATABASE: “xxx”
MYSQL_USER: “xxx”
MYSQL_PASSWORD: “xxx”
volumes:
- /mnt/usb1/nginx-proxy-manager/mysql:/var/lib/mysql
nextcloudpi:
image: ownyourbits/nextcloudpi:latest
ports:
- “4444:443”
- “4443:4443”
volumes:
- /mnt/usb1/nextcloudpi:/data
- /etc/localtime:/etc/localtime:ro
container_name: nextcloudpi
portainer:
image: portainer/portainer
command: -H unix:///var/run/docker.sock
ports:
- 9000:9000
- 8000:8000
container_name: portainer
volumes:
- /var/run/docker.sock:/var/run/docker.sock
- /mnt/usb1/portainer/data:/data
Yes
- Install Docker on RPI (all over wifi)
- Install nextcloudpi Docker Container
- Configure containers
- Switch of WiFi and use ethernet
pi@rpi4:~ $ sudo cat /mnt/usb1/nextcloudpi/nextcloud/config/config.php
'passwordsalt' => '',
'secret' => '',
0 => 'localhost',
11 => '84.183.42.4',
1 => '172.18.0.4',
5 => 'nextcloudpi.local',
7 => 'nextcloudpi',
8 => 'nextcloudpi.lan',
20 => 'rpi4',
21 => 'nextcloud.MYNAME.duckdns.org',
'datadirectory' => '/data/nextcloud/data',
'version' => '18.0.3.0',
'overwrite.cli.url' => 'http://localhost',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'ncadmin',
'dbpassword' => ''
'instanceid' => 'ocof344kq2sc',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,
'password' => '',
'tempdirectory' => '/var/www/nextcloud/data/tmp',
'mail_smtpmode' => 'sendmail',
'mail_from_address' => 'admin',
'mail_domain' => 'ownyourbits.com',
'preview_max_x' => '2048',
'preview_max_y' => '2048',
'jpeg_quality' => '60',
'overwritehost' => 'nextcloud.MYNAME.duckdns.org:4444',
I am glad for any hint!!!
Kind regards
Psy
