i dont need this cr.. stuff and i wanât have it out if the information, as private user of Nextcloud to i donât need something and it is easy distrub in my Administration Space.
and i want not have a say âyou have install this and this and this !!â therefor should it give a possible for diable some reports, maybe a panel on top (disabled Reports with checkboxes)
for have the possible to disable some Reports and error-polls on Private cloudâs .
well as a matter of fact you shouldnât use your admin account for your daily business. and those messages donât really nag you with popups here and there, they only show up if you are going there by yourself.
Apart from that: have you installted 2 factor? So you should setup it correctly. If you donât use it, I suggest to remove the whole app. It would helo getting rid of the 2nd âerrorâ
The setup for emails is, as I think, mandatory and important to NC. so you should set up that one correctly. I, myself, see that as an âerrorâ and not only as a notice.
Hi @JimmyKater ,
Ah, I see, so it can be uninstalled?
I just checked and couldnât find it under âActive Appsâ in the admin section. So yeah, I donât have 2FA installed, nor a recording backend, nor SIP (Iâll use SIP once Iâve finally got my AI running on the Pi, but until then those messages are just annoying, and this is a private NC instance, but thanks for the hint anyway, my Dear ! :))
I mean, I certainly wouldnât mind if those ârecommendationalâ messages were in a separate section or could be acknowledged and then disappear to a hidden âacknowledgedâ messages section.
On the other hand, these are mainly cosmetic issues, and since developer time is limited and Nextcloud has a lot of things to work on, Iâd rather see the devs working on things that actually matter.
