Sudden constant disconnects/maintenance mode and high CPU usage
Hi
My windows client (windows-10.0.19045) recently started experiencing weird disconnects. The only way to connect again is to kill/restart the client.
When i looked into it I noticed that the webpage frequently (10-30 times an hour) states ā€œMaintenance Modeā€, and then after a few seconds or minutes displays the file list after refreshing the page a few times.
These brief switches to maintenance mode coincide with the windows client permanently loosing its connection.
When investigating further, I noticed that the CPU load was constantly high (50-90%) which is weird because it has been running on 1-20% mostly for the last few years.
Giving the VM (qemu/proxmox) two more cores and doubling the RAM (4 → 8GB) mitigated the CPU load linearly, but did not stop the constant maintenance modes/disconnects.
I am only one user with four devices accessing the server, this has not changed for the past 2-3 years.
My server is 25.0.6, running as a snap on Ubuntu 22.04.2 LTS (fully updated, both Snap and packages).
The logs in nextcoud present the followin two errors frequently:
  1. " OCA\Circles\Exceptions\MigrationException: A migration process is already running"
  2. ā€œDoctrine\DBAL\Exception\UniqueConstraintViolationException: An exception occurred while executing a query: SQLSTATE[23000]: Integrity constraint violation: 1062 Duplicate entry ā€˜625-bookmark-1’ for key ā€˜oc_bookmarks_tree.PRIMARYā€™ā€
I’m scratching my head and do not even know where to start looking for a source to this… Any help or guidance would be greatly appreciated.
I think I finally solved it.
First I set the logging policy to ā€œwarningā€ instead of the default setting ā€œdebugā€, which actually lowered the load from above 1 to 0.90-0.99.
The second error message stated that there was no app involved, but when I read it more carefully I saw that it repeatedly mentions ā€œbookmarkā€ in the body of the message.
I disabled the ā€œbookmarksā€ app and the error dissappeared, and now the server runs smoothly/stably again.
I liked the bookmarks app, but I guess I’ll have to look for an alternative.
