[details=“Support intro”]
looking for a Nextcloud app like Doodle
Calendar / Appointments do not appear to have a feature to select meeting times from a selection list. Is there a Nextcloud App that is good for this?
Just a question about finding an App.
Nextcloud version (eg, 20.0.5): replace me
Operating system and version (eg, Ubuntu 20.04): replace me
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): replace me
The issue you are facing: simple - described above.
- Ask the question!
n/a
n/a
n/a
n/a
j/a
