NextCloud: 22.2.3
Hansson IT OVA setup on Ubuntu 20.04.2
I own a block of static WAN IP addresses.
The Wan to LAN traffic is on ..187.11
The Web traffic is going out the gateway at ..187.13
NextCloud and all the Certificates all work properly, The issue is that since the web traffic is going out the gateway it reports that the static ip is dot13. This causes the STUN server to incorrectly report the dot13 wan static ip address to the tallk devices.
I was able to confirm the STUN server reporting the wrong IP using the tool below. Attached is a screenshot.
https://webrtc.github.io/samples/src/content/peerconnection/trickle-ice/
Since this is a STATIC wan IP address am I able to set this manually in the STUN server to the correct ip address of the nextcloud instance of dot11?
Some Pictures of the URLS resolving correctly.
Cloud Main URL
Talk URL
Let me know if you have any questions!
Thank you
