example
longer
example
here
Nextcloud version (eg, 20.0.5): 25.0.2
Operating system and version (eg, Ubuntu 20.04): replace me
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): 8.1
After setting maintenance mode, it is not possible to get out. The results from occ and status.php differ:
./occ status:
- installed: true
- version: 25.0.2.3
- versionstring: 25.0.2
- edition:
- maintenance: false
- needsDbUpgrade: false
- productname: Nextcloud
- extendedSupport: false
/status.php:
{“installed”:true,“maintenance”:true,“needsDbUpgrade”:false,“version”:“25.0.2.3”,“versionstring”:“25.0.2”,“edition”:“”,“productname”:“Nextcloud”,“extendedSupport”:false}
./occ maintenance:mode --off
Maintenance mode already disabled
Is this the first time you’ve seen this error? (Y/N): Yes
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
PASTE HERE
