example
longer
example
here
Nextcloud version (eg, 20.0.5): 25.0.2
Operating system and version (eg, Ubuntu 20.04): ? (web hoster)
Apache or nginx version (eg, Apache 2.4.25): ? (web hoster)
PHP version (eg, 7.4): 8.1
I started an update from NCv25.0.2 to NCv25.0.3 vi the web updater.
My NC instance is stuck in Maintenance mode.
Unfortunately I only have FTP access to NC, wehre I tried already the following:
- .user.ini
memory_limit=256M
max_execution_time=300 - config.php
‘maintenance’ => false,
But no success. I am stuck in maintenance mode.
Is this the first time you’ve seen this error? Y:
In the past I this happened to me as well, but resetting the maintenance flag in config.php (several times) helped me out of this situation.
'instanceid' => 'xxxxxxxxxxxxxxxxx',
'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxxxxxx',
'secret' => 'rxxxxxxxxxxxxxxxxxxxxx',
0 => 'xxxxxxx.net',
1 => 'www.xxxxxxx.net',
'datadirectory' => '/www/htdocs/xxxxxxxxx.net/data',
'version' => '25.0.2.3',
'overwrite.cli.url' => 'http://xxxxx.net',
'dbname' => 'dxxxxxxxxx',
'dbhost' => 'localhost',
'dbtableprefix' => 'xxxxxxxx',
'dbuser' => 'xxxxxxxxx',
'dbpassword' => 'xxxxxxxxxxxxx',
'tempdirectory' => '/www/htdocs/xxxxxxxxxxxxx/data/tmp/',
'mail_smtpmode' => 'sendmail',
'mail_sendmailmode' => 'pipe',
'mail_from_address' => 'xxxxxxx',
'mail_domain' => 'xxxxxxx',
'theme' => '',
'loglevel' => 0,
'app_install_overwrite' =>
0 => 'calendar',
'updater.secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxx,
Update to 25.0.3
An error occurred.
Detailed logs
Preparing update
Set log level to debug
Turned on maintenance mode
Repair step: Repair MySQL collation
Repair info: All tables already have the correct collation → nothing to do
Repair step: Repair SQLite autoincrement
Repair step: Copy data from accounts table when migrating from ownCloud
Repair step: Drop account terms table when migrating from ownCloud
Updating database schema
Updated database
An error occurred.
