Nextcloud version : 17.0.2
Operating system and version : Ubuntu 18.04.3 LTS
Apache or nginx version : Apache/2.4.29
PHP version : 7.2
Today I tried to upgrade to 17.0.2 (from 17.0.1) via the integrated updater. I constantly received errors during either Backup or Extracting. So I tried the commandline updater, but noticed, that version.php was somewhat stuck at some 13.x version and totally out of date (at least updater.phar kept showing me these versions). So I thought it wouldn’t hurt if I get a fresh copy and import the config.php, as described in the nextcloud wiki.
Moved the old installation to _old and extracted a new copy of nextcloud 17.0.2 to /var/www/nextcloud. Moved over the config file from _old, adjusted file permissions and ran occ upgrade. (https://docs.nextcloud.com/server/17/admin_manual/maintenance/manual_upgrade.html)
Nextcloud does show up, but it is still in maintenance mode. And I tried every method I could think of to disable it:
- occ maintenance:mode --off (also turning it on and off several times)
- occ config:system:set maintenance --value=false --type=bool
- occ upgrade (again, returns: Nextcloud is already latest version")
- php updater.phar (version 16.0.3-3-ga0c2b25 dirty) returns: “Current Version is 17.0.2, No update available.”
- occ maintenance:repair
- manually setting maintenance to false in the config.php
- restarted apache2 several times
- rebooted the VM several times
- ran apt update and apt upgrade
Even when reverting back to the _old folder it is still in maintenance mode.
I rebooted my pc, cleared the cache of Firefox, tried to use edge. Always - the same - result.
And lastly, I even copied a backup from the data directory/updater/backups/ back to the web-root, still maintenance mode active. I’m starting to think it’s not coming from the webroot but rather the data directory or database …
Any ideas ?
Is this the first time you’ve seen this error? : Y
- Always present
*removed*
*removed*
