Hi all; tried to online-update a running nextcloud (12.x?) instance on a shared hoster. Failed in “downloading” because apparently our internal firewall somehow blocked the download, with the updater complaining the download failed. Wanted to try the same thing later at home - just to experience after closing the browser tab I can’t even reach the admin page anymore. System says the instance is in maintenance mode.
Is there a way to get rid of maintenance mode again? Browsing the web I found two options to use occ command line tool for that (which I can’t as I don’t have shell access to the machine) or to remove or set to false the “maintenance” parameter in config.php (which doesn’t work).
How to get out of this mess?
Thanks in advance and all the best,
Kristian
No problem. I’ll see whether I can get the status output to work again; meanwhile I tried to restore the instance from the backup the updater (successfully) managed to create - which seems to have completely trashed it. Not nextclouds fault this time, however, but it seems rather a permission issue on my hosters side. More later, I hope…
Thanks so far for your help,
Kristian
