Stuck in maintenance after update because of group folder
    • 32.0.1.2
    • linux, unsure (docker)
    • unknown
    • nginx
    • unknown
    • yes
    • after upgrade from 32.0.0.13
    • unraid docker
    • no
After upgrading, the log file show:
Initializing nextcloud 32.0.1.2 (this can take a while) …
Upgrading nextcloud from 32.0.0.13 …
Setting permissions
Setting log level to debug
Turned on maintenance mode
Updating database schema
Updated database
Updating …
Updated to 6.0.1
Update app groupfolders from App Store
ArgumentCountError: Too few arguments to function OCA\GroupFolders\Folder\FolderDefinition::__construct(), 6 passed in /config/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php on line 552 and exactly 7 expected in /config/www/nextcloud/apps/groupfolders/lib/Folder/FolderDefinition.php:12
Stack trace:
#0 /config/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php(552): OCA\GroupFolders\Folder\FolderDefinition->__construct()
#1 /config/www/nextcloud/apps/groupfolders/lib/Folder/FolderManager.php(87): OCA\GroupFolders\Folder\FolderManager->rowToFolder()
#2 /config/www/nextcloud/apps/groupfolders/lib/Migration/WrongDefaultQuotaRepairStep.php(32): OCA\GroupFolders\Folder\FolderManager->getAllFolders()
#3 /app/www/public/lib/private/Repair.php(107): OCA\GroupFolders\Migration\WrongDefaultQuotaRepairStep->run()
#4 /app/www/public/lib/private/legacy/OC_App.php(574): OC\Repair->run()
#5 /app/www/public/lib/private/App/AppManager.php(1059): OC_App::executeRepairSteps()
#6 /app/www/public/lib/private/Installer.php(111): OC\App\AppManager->upgradeApp()
#7 /app/www/public/lib/private/Updater.php(381): OC\Installer->updateAppstoreApp()
#8 /app/www/public/lib/private/Updater.php(242): OC\Updater->upgradeAppStoreApps()
#9 /app/www/public/lib/private/Updater.php(100): OC\Updater->doUpgrade()
#10 /app/www/public/core/Command/Upgrade.php(193): OC\Updater->upgrade()
#11 /app/www/public/3rdparty/symfony/console/Command/Command.php(326): OC\Core\Command\Upgrade->execute()
#12 /app/www/public/3rdparty/symfony/console/Application.php(1078): Symfony\Component\Console\Command\Command->run()
#13 /app/www/public/3rdparty/symfony/console/Application.php(324): Symfony\Component\Console\Application->doRunCommand()
#14 /app/www/public/3rdparty/symfony/console/Application.php(175): Symfony\Component\Console\Application->doRun()
#15 /app/www/public/lib/private/Console/Application.php(187): Symfony\Component\Console\Application->run()
#16 /app/www/public/console.php(90): OC\Console\Application->run()
#17 /app/www/public/occ(33): require_once(‘…’)
#18 {main}Initializing finished
Now interface shows maintenance is running forever
{"reqId":"F3kyzQXWcxm5OKVE01e0","level":0,"time":"2025-10-29T15:51:04+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"2MzqOY6Qtt2mYam6iNHO","level":0,"time":"2025-10-29T15:51:05+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"eaZHPdfWMldqam5uZoj6","level":0,"time":"2025-10-29T15:51:05+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"NPwuugkYwVXYgeaGC656","level":0,"time":"2025-10-29T15:51:06+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"ZqojOeEnwSZ2LSsaRUIX","level":0,"time":"2025-10-29T15:51:06+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"ZqojOeEnwSZ2LSsaRUIX","level":0,"time":"2025-10-29T15:51:07+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"6MiiOqJ43pXkiNNGjnrB","level":0,"time":"2025-10-29T15:51:07+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"N6A6UhQgeMDmjWeAkrGl","level":0,"time":"2025-10-29T15:51:07+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"N6A6UhQgeMDmjWeAkrGl","level":0,"time":"2025-10-29T15:51:08+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"S82x0kaiPfKYIbkr4unT","level":0,"time":"2025-10-29T15:51:08+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"bijs0Wwr0CzDZ70ymhp9","level":0,"time":"2025-10-29T15:51:08+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"bijs0Wwr0CzDZ70ymhp9","level":0,"time":"2025-10-29T15:51:09+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"ZWonky3W2KasFJQOSVwW","level":0,"time":"2025-10-29T15:51:09+00:00","remoteAddr":"","user":"--","app":"serverDI","method":"","url":"--","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"--","version":"32.0.1.2","data":{"app":"serverDI"}}
{"reqId":"wlr57Dq7M0DBsWbqHkai","level":0,"time":"2025-10-29T15:51:17+00:00","remoteAddr":"192.168.0.121","user":"--","app":"serverDI","method":"GET","url":"/index.php/204","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"Mozilla/5.0 (Windows) mirall/4.0.0 (build 20251021) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"32.0.1.2","clientReqId":"a1e2c595-b4ed-4d21-b1ab-f0a810e3a7c2","data":{"app":"serverDI"}}
{"reqId":"wlr57Dq7M0DBsWbqHkai","level":1,"time":"2025-10-29T15:51:18+00:00","remoteAddr":"192.168.0.121","user":"--","app":"no app in context","method":"GET","url":"/index.php/204","message":"Unable to generate a URL for the named route \"ocs.password_policy.api.generate\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows) mirall/4.0.0 (build 20251021) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"32.0.1.2","clientReqId":"a1e2c595-b4ed-4d21-b1ab-f0a810e3a7c2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"ocs.password_policy.api.generate\" as such route does not exist.","Code":0,"Trace":[{"file":"/app/www/public/lib/private/Route/Router.php","line":413,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/app/www/public/lib/private/Route/CachingRouter.php","line":56,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/app/www/public/lib/private/URLGenerator.php","line":99,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/config/www/nextcloud/apps/password_policy/lib/Capabilities.php","line":66,"function":"linkToOCSRouteAbsolute","class":"OC\\URLGenerator","type":"->"},{"file":"/app/www/public/lib/private/CapabilitiesManager.php","line":61,"function":"getCapabilities","class":"OCA\\Password_Policy\\Capabilities","type":"->"},{"file":"/app/www/public/lib/private/Template/JSConfigHelper.php","line":142,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/app/www/public/lib/private/TemplateLayout.php","line":239,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/app/www/public/lib/private/Template/Template.php","line":115,"function":"getPageTemplate","class":"OC\\TemplateLayout","type":"->"},{"file":"/app/www/public/lib/private/Template/Base.php","line":103,"function":"fetchPage","class":"OC\\Template\\Template","type":"->"},{"file":"/app/www/public/lib/base.php","line":248,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/base.php","line":997,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/app/www/public/index.php","line":25,"function":"handleRequest","class":"OC","type":"::"}],"File":"/app/www/public/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":134,"message":"Unable to generate a URL for the named route \"ocs.password_policy.api.generate\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"ocs.password_policy.api.generate\" as such route does not exist."}}
{"reqId":"wlr57Dq7M0DBsWbqHkai","level":1,"time":"2025-10-29T15:51:18+00:00","remoteAddr":"192.168.0.121","user":"--","app":"no app in context","method":"GET","url":"/index.php/204","message":"Unable to generate a URL for the named route \"ocs.password_policy.api.validate\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows) mirall/4.0.0 (build 20251021) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"32.0.1.2","clientReqId":"a1e2c595-b4ed-4d21-b1ab-f0a810e3a7c2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"ocs.password_policy.api.validate\" as such route does not exist.","Code":0,"Trace":[{"file":"/app/www/public/lib/private/Route/Router.php","line":413,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/app/www/public/lib/private/Route/CachingRouter.php","line":56,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/app/www/public/lib/private/URLGenerator.php","line":99,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/config/www/nextcloud/apps/password_policy/lib/Capabilities.php","line":67,"function":"linkToOCSRouteAbsolute","class":"OC\\URLGenerator","type":"->"},{"file":"/app/www/public/lib/private/CapabilitiesManager.php","line":61,"function":"getCapabilities","class":"OCA\\Password_Policy\\Capabilities","type":"->"},{"file":"/app/www/public/lib/private/Template/JSConfigHelper.php","line":142,"function":"getCapabilities","class":"OC\\CapabilitiesManager","type":"->"},{"file":"/app/www/public/lib/private/TemplateLayout.php","line":239,"function":"getConfig","class":"OC\\Template\\JSConfigHelper","type":"->"},{"file":"/app/www/public/lib/private/Template/Template.php","line":115,"function":"getPageTemplate","class":"OC\\TemplateLayout","type":"->"},{"file":"/app/www/public/lib/private/Template/Base.php","line":103,"function":"fetchPage","class":"OC\\Template\\Template","type":"->"},{"file":"/app/www/public/lib/base.php","line":248,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/base.php","line":997,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/app/www/public/index.php","line":25,"function":"handleRequest","class":"OC","type":"::"}],"File":"/app/www/public/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":134,"message":"Unable to generate a URL for the named route \"ocs.password_policy.api.validate\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"ocs.password_policy.api.validate\" as such route does not exist."}}
{"reqId":"wlr57Dq7M0DBsWbqHkai","level":1,"time":"2025-10-29T15:51:18+00:00","remoteAddr":"192.168.0.121","user":"--","app":"no app in context","method":"GET","url":"/index.php/204","message":"Capabilities of OCA\\Password_Policy\\Capabilities took 0.4 seconds to generate.","userAgent":"Mozilla/5.0 (Windows) mirall/4.0.0 (build 20251021) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"32.0.1.2","clientReqId":"a1e2c595-b4ed-4d21-b1ab-f0a810e3a7c2","data":[]}
{"reqId":"wlr57Dq7M0DBsWbqHkai","level":1,"time":"2025-10-29T15:51:18+00:00","remoteAddr":"192.168.0.121","user":"--","app":"no app in context","method":"GET","url":"/index.php/204","message":"Unable to generate a URL for the named route \"activity.activities.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows) mirall/4.0.0 (build 20251021) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"32.0.1.2","clientReqId":"a1e2c595-b4ed-4d21-b1ab-f0a810e3a7c2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"activity.activities.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/app/www/public/lib/private/Route/Router.php","line":413,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/app/www/public/lib/private/Route/CachingRouter.php","line":56,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/app/www/public/lib/private/URLGenerator.php","line":81,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/app/www/public/lib/private/NavigationManager.php","line":365,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/app/www/public/lib/private/NavigationManager.php","line":125,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/config/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":143,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/app/www/public/lib/private/legacy/OC_Defaults.php","line":247,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/app/www/public/lib/public/Defaults.php","line":153,"function":"getLongFooter","class":"OC_Defaults","type":"->"},{"file":"/app/www/public/core/templates/layout.guest.php","line":61,"function":"getLongFooter","class":"OCP\\Defaults","type":"->"},{"file":"/app/www/public/lib/private/Template/Base.php","line":140,"args":["/app/www/public/core/templates/layout.guest.php"],"function":"include"},{"file":"/app/www/public/lib/private/Template/Base.php","line":113,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/private/Template/Template.php","line":112,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/private/Template/Template.php","line":142,"function":"fetchPage","class":"OC\\Template\\Template","type":"->"},{"file":"/app/www/public/lib/private/Template/Base.php","line":103,"function":"fetchPage","class":"OC\\Template\\Template","type":"->"},{"file":"/app/www/public/lib/base.php","line":248,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/base.php","line":997,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/app/www/public/index.php","line":25,"function":"handleRequest","class":"OC","type":"::"}],"File":"/app/www/public/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":134,"message":"Unable to generate a URL for the named route \"activity.activities.index\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"activity.activities.index\" as such route does not exist."}}
{"reqId":"wlr57Dq7M0DBsWbqHkai","level":1,"time":"2025-10-29T15:51:18+00:00","remoteAddr":"192.168.0.121","user":"--","app":"no app in context","method":"GET","url":"/index.php/204","message":"Unable to generate a URL for the named route \"files.view.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows) mirall/4.0.0 (build 20251021) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"32.0.1.2","clientReqId":"a1e2c595-b4ed-4d21-b1ab-f0a810e3a7c2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"files.view.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/app/www/public/lib/private/Route/Router.php","line":413,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/app/www/public/lib/private/Route/CachingRouter.php","line":56,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/app/www/public/lib/private/URLGenerator.php","line":81,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/app/www/public/lib/private/NavigationManager.php","line":365,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/app/www/public/lib/private/NavigationManager.php","line":125,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/config/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":143,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/app/www/public/lib/private/legacy/OC_Defaults.php","line":247,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/app/www/public/lib/public/Defaults.php","line":153,"function":"getLongFooter","class":"OC_Defaults","type":"->"},{"file":"/app/www/public/core/templates/layout.guest.php","line":61,"function":"getLongFooter","class":"OCP\\Defaults","type":"->"},{"file":"/app/www/public/lib/private/Template/Base.php","line":140,"args":["/app/www/public/core/templates/layout.guest.php"],"function":"include"},{"file":"/app/www/public/lib/private/Template/Base.php","line":113,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/private/Template/Template.php","line":112,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/private/Template/Template.php","line":142,"function":"fetchPage","class":"OC\\Template\\Template","type":"->"},{"file":"/app/www/public/lib/private/Template/Base.php","line":103,"function":"fetchPage","class":"OC\\Template\\Template","type":"->"},{"file":"/app/www/public/lib/base.php","line":248,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/base.php","line":997,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/app/www/public/index.php","line":25,"function":"handleRequest","class":"OC","type":"::"}],"File":"/app/www/public/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":134,"message":"Unable to generate a URL for the named route \"files.view.index\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"files.view.index\" as such route does not exist."}}
{"reqId":"wlr57Dq7M0DBsWbqHkai","level":1,"time":"2025-10-29T15:51:18+00:00","remoteAddr":"192.168.0.121","user":"--","app":"no app in context","method":"GET","url":"/index.php/204","message":"Unable to generate a URL for the named route \"notes.page.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows) mirall/4.0.0 (build 20251021) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"32.0.1.2","clientReqId":"a1e2c595-b4ed-4d21-b1ab-f0a810e3a7c2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"notes.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/app/www/public/lib/private/Route/Router.php","line":413,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/app/www/public/lib/private/Route/CachingRouter.php","line":56,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/app/www/public/lib/private/URLGenerator.php","line":81,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/app/www/public/lib/private/NavigationManager.php","line":365,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/app/www/public/lib/private/NavigationManager.php","line":125,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/config/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":143,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/app/www/public/lib/private/legacy/OC_Defaults.php","line":247,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/app/www/public/lib/public/Defaults.php","line":153,"function":"getLongFooter","class":"OC_Defaults","type":"->"},{"file":"/app/www/public/core/templates/layout.guest.php","line":61,"function":"getLongFooter","class":"OCP\\Defaults","type":"->"},{"file":"/app/www/public/lib/private/Template/Base.php","line":140,"args":["/app/www/public/core/templates/layout.guest.php"],"function":"include"},{"file":"/app/www/public/lib/private/Template/Base.php","line":113,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/private/Template/Template.php","line":112,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/private/Template/Template.php","line":142,"function":"fetchPage","class":"OC\\Template\\Template","type":"->"},{"file":"/app/www/public/lib/private/Template/Base.php","line":103,"function":"fetchPage","class":"OC\\Template\\Template","type":"->"},{"file":"/app/www/public/lib/base.php","line":248,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/base.php","line":997,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/app/www/public/index.php","line":25,"function":"handleRequest","class":"OC","type":"::"}],"File":"/app/www/public/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":134,"message":"Unable to generate a URL for the named route \"notes.page.index\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"notes.page.index\" as such route does not exist."}}
{"reqId":"wlr57Dq7M0DBsWbqHkai","level":1,"time":"2025-10-29T15:51:18+00:00","remoteAddr":"192.168.0.121","user":"--","app":"no app in context","method":"GET","url":"/index.php/204","message":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist.","userAgent":"Mozilla/5.0 (Windows) mirall/4.0.0 (build 20251021) (Nextcloud, windows-10.0.26100 ClientArchitecture: x86_64 OsArchitecture: x86_64)","version":"32.0.1.2","clientReqId":"a1e2c595-b4ed-4d21-b1ab-f0a810e3a7c2","exception":{"Exception":"Symfony\\Component\\Routing\\Exception\\RouteNotFoundException","Message":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist.","Code":0,"Trace":[{"file":"/app/www/public/lib/private/Route/Router.php","line":413,"function":"generate","class":"Symfony\\Component\\Routing\\Generator\\UrlGenerator","type":"->"},{"file":"/app/www/public/lib/private/Route/CachingRouter.php","line":56,"function":"generate","class":"OC\\Route\\Router","type":"->"},{"file":"/app/www/public/lib/private/URLGenerator.php","line":81,"function":"generate","class":"OC\\Route\\CachingRouter","type":"->"},{"file":"/app/www/public/lib/private/NavigationManager.php","line":365,"function":"linkToRoute","class":"OC\\URLGenerator","type":"->"},{"file":"/app/www/public/lib/private/NavigationManager.php","line":125,"function":"init","class":"OC\\NavigationManager","type":"->"},{"file":"/config/www/nextcloud/apps/theming/lib/ThemingDefaults.php","line":143,"function":"getAll","class":"OC\\NavigationManager","type":"->"},{"file":"/app/www/public/lib/private/legacy/OC_Defaults.php","line":247,"function":"getShortFooter","class":"OCA\\Theming\\ThemingDefaults","type":"->"},{"file":"/app/www/public/lib/public/Defaults.php","line":153,"function":"getLongFooter","class":"OC_Defaults","type":"->"},{"file":"/app/www/public/core/templates/layout.guest.php","line":61,"function":"getLongFooter","class":"OCP\\Defaults","type":"->"},{"file":"/app/www/public/lib/private/Template/Base.php","line":140,"args":["/app/www/public/core/templates/layout.guest.php"],"function":"include"},{"file":"/app/www/public/lib/private/Template/Base.php","line":113,"function":"load","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/private/Template/Template.php","line":112,"function":"fetchPage","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/private/Template/Template.php","line":142,"function":"fetchPage","class":"OC\\Template\\Template","type":"->"},{"file":"/app/www/public/lib/private/Template/Base.php","line":103,"function":"fetchPage","class":"OC\\Template\\Template","type":"->"},{"file":"/app/www/public/lib/base.php","line":248,"function":"printPage","class":"OC\\Template\\Base","type":"->"},{"file":"/app/www/public/lib/base.php","line":997,"function":"checkMaintenanceMode","class":"OC","type":"::"},{"file":"/app/www/public/index.php","line":25,"function":"handleRequest","class":"OC","type":"::"}],"File":"/app/www/public/3rdparty/symfony/routing/Generator/UrlGenerator.php","Line":134,"message":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist.","exception":{},"CustomMessage":"Unable to generate a URL for the named route \"photos.page.index\" as such route does not exist."}}
Irrelevant
Can't access
Nextcloud is in maintenance mode, no apps are loaded.
Commands provided by apps are unavailable.
            "192.168.0.4:7443",
            "nextcloud.servraid.duckdns.org",
            "192.168.5.6:7443"
        "dbtype": "mysql",
        "version": "32.0.1.2",
        "overwrite.cli.url": "https:\/\/nextcloud.servraid.duckdns.org",
        "dbport": "3306",
        "mysql.utf8mb4": true,
        "redis": {
            "port": 6379
        "filelocking.enabled": true,
        "upgrade.disable-web": true,
        "maintenance": true,
        "default_phone_region": "ca",
        "forbidden_filename_basenames": [
            "con",
            "prn",
            "aux",
            "nul",
            "com0",
            "com1",
            "com2",
            "com3",
            "com4",
            "com5",
            "com6",
            "com7",
            "com8",
            "com9",
            "com\u00b9",
            "com\u00b2",
            "com\u00b3",
            "lpt0",
            "lpt1",
            "lpt2",
            "lpt3",
            "lpt4",
            "lpt5",
            "lpt6",
            "lpt7",
            "lpt8",
            "lpt9",
            "lpt\u00b9",
            "lpt\u00b2",
            "lpt\u00b3"
        "forbidden_filename_characters": [
        "forbidden_filename_extensions": [
            ".filepart",
            ".part"
        "mail_smtpmode": "smtp",
        "mail_smtpsecure": "ssl",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "465",
        "mail_smtpauth": true,
        "app_install_overwrite": [
            "user_migration"
        "loglevel": 0
This suggests a mixture of code from the wrong group folders app version.
Based on the error it may just be a PHP caching matter. From what I can tell you’re likely using the LSIO image? I don’t know how they have PHP set-up, but it may be as simple as restarting the container.
From the looks of it, you were running an outdated groupfolders version (v20.0.1?) prior to attempting the update (it’s generally recommended to update all apps ahead of time if possible).
The code looks correct in the released version from what I can see.
Weirdly can’t edit. I restarted the docker and it properly updated. But I’m still stuck in maintenance
Setting permissions
Updated database
Updating …
Updated to 20.1.2
Starting code integrity check…
Finished code integrity check
Update successful
Maintenance mode is kept active
Resetting log level
ok so I’m unsure if I did more harm then good. I did the following.
I ran the following occ command, then restarted. No more maintenance mode and I can access my nextcloud webui, desktop client are also working
occ maintenance:data-fingerprint
occ maintenance:mimetype:update-db
occ maintenance:mimetype:update-js
occ maintenance:repair
occ maintenance:theme:update
occ maintenance:update:htaccess
occ maintenance:mode –off
restarted and log.
beware of this command
it makes your client become a master of the data. look at the docs for details.
I don’t really get what that mean. Looking at the do, I only find this
After restoring a backup of your data directory or the database, you should always call maintenance:data-fingerprint once. This changes the ETag for all files in the communication with sync clients, allowing them to realize a file was modified.
ok, but I’ve run it, so… now what?
