I have NC ver 15.0.5.3 installed on QNAP NAS (64 bit, Intel 4 core, 16 GB RAM, MySQL as DB). Linux client ver 2.5.2 AppImage on Linux desktop. I want client to login to NC via http not via WebFlow because WebFlow does not allow integration with KWallet. So I changed in ~/.config/Nextcloud/nexcloud.cfg file entry authType=webflow to authType=http. But after several seconds this entry change itself to authType=webflow does not matter I am logged to NC or not. So WebFlow screen appears anyway.
How to force client do not change that entry?
Log file from client:
OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/" has X-Request-ID "7cd777f1-e1d9-45b7-87db-e1acf35ef833"
[OCC::AbstractNetworkJob::start OCC::PropfindJob created for "https://example.domain.com" + "/" "OCC::ConnectionValidator"
[OCC::AccountManager::saveAccount Saving account "https://example.domain.com:45083"
[OCC::AccountManager::saveAccountHelper Saving 3 unknown certs.
[OCC::AccountManager::saveAccountHelper Saving cookies. "/home/maciek/.config/Nextcloud/cookies1.db"
[OCC::AccountManager::saveAccount Saved account settings, status: QSettings::Status(NoError)
[OCC::Account::slotHandleSslErrors "SSL-Errors happened for url \"https://example.domain.com:45083/remote.php/dav/files/maciek/\" \tError in QSslCertificate(\"3\", \"bd:fa:64:1e:eb:e7:50:03\", \"zuyf5JZCeCpjF40/xr/Wiw==\", (\"QoolBox\"), (\"QoolBox\"), QMap(), QDateTime(2018-10-01 03:56:42.000 UTC Qt::TimeSpec(UTC)), QDateTime(2028-09-28 03:56:42.000 UTC Qt::TimeSpec(UTC))) : \"The host name did not match any of the valid hosts for this certificate\" ( \"The host name did not match any of the valid hosts for this certificate\" ) \n " Certs are known and trusted! This is not an actual error.
[OCC::WebFlowCredentials::slotFinished request finished
[OCC::PropfindJob::finished PROPFIND of QUrl("https://example.domain.com:45083/remote.php/dav/files/maciek/") FINISHED WITH STATUS "OK"
[OCC::Folder::slotRunEtagJob Trying to check "https://example.domain.com:45083/remote.php/dav/files/maciek/Zdjęcia" for changes via ETag check. (time since last sync: 242 s)
[OCC::Folder::slotRunEtagJob Trying to check "https://example.domain.com:45083/remote.php/dav/files/maciek/Dokumenty" for changes via ETag check. (time since last sync: 239 s)
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/Zdjęcia" has X-Request-ID "a7825344-e21f-4494-8a39-bfb8c30e3e2f"
[OCC::AbstractNetworkJob::start OCC::RequestEtagJob created for "https://example.domain.com" + "/Zdjęcia" "OCC::Folder"
[OCC::Account::slotHandleSslErrors "SSL-Errors happened for url \"https://example.domain.com:45083/remote.php/dav/files/maciek/Zdjęcia\" \tError in QSslCertificate(\"3\", \"bd:fa:64:1e:eb:e7:50:03\", \"zuyf5JZCeCpjF40/xr/Wiw==\", (\"QoolBox\"), (\"QoolBox\"), QMap(), QDateTime(2018-10-01 03:56:42.000 UTC Qt::TimeSpec(UTC)), QDateTime(2028-09-28 03:56:42.000 UTC Qt::TimeSpec(UTC))) : \"The host name did not match any of the valid hosts for this certificate\" ( \"The host name did not match any of the valid hosts for this certificate\" ) \n " Certs are known and trusted! This is not an actual error.
[OCC::RequestEtagJob::finished Request Etag of QUrl("https://example.domain.com:45083/remote.php/dav/files/maciek/Zdjęcia") FINISHED WITH STATUS "OK"
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/Dokumenty" has X-Request-ID "214923ee-7e52-4a0c-bad0-9385914e8879"
[OCC::AbstractNetworkJob::start OCC::RequestEtagJob created for "https://example.domain.com" + "/Dokumenty" "OCC::Folder"
[OCC::RequestEtagJob::finished Request Etag of QUrl("https://example.domain.com:45083/remote.php/dav/files/maciek/Dokumenty") FINISHED WITH STATUS "OK"
[OCC::AccessManager::createRequest 2 "" "https://example.domain.com:45083/ocs/v2.php/apps/notifications/api/v2/notifications?format=json" has X-Request-ID "2c3faaa3-9e8f-4903-96e4-f7549eb3f499"
[OCC::AbstractNetworkJob::start OCC::JsonApiJob created for "https://example.domain.com" + "ocs/v2.php/apps/notifications/api/v2/notifications" "OCC::ServerNotificationHandler"
[OCC::JsonApiJob::finished JsonApiJob of QUrl("https://example.domain.com:45083/ocs/v2.php/apps/notifications/api/v2/notifications?format=json") FINISHED WITH STATUS "OK"
[OCC::JsonApiJob::finished Nothing changed so nothing to retrieve - status code: 304
[OCC::ServerNotificationHandler::slotNotificationsReceived Status code 304 Not Modified - No new notifications.
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/" has X-Request-ID "3ac422a7-56ba-4e66-852e-f50ecfe77e9e"
[OCC::AbstractNetworkJob::start OCC::PropfindJob created for "https://example.domain.com" + "/" "OCC::QuotaInfo"
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/" has X-Request-ID "914167e6-5275-4db5-b762-25c440c912e0"
[OCC::Folder::slotRunEtagJob Trying to check "https://example.domain.com:45083/remote.php/dav/files/maciek/Zdjęcia" for changes via ETag check. (time since last sync: 272 s)
[OCC::Folder::slotRunEtagJob Trying to check "https://example.domain.com:45083/remote.php/dav/files/maciek/Dokumenty" for changes via ETag check. (time since last sync: 269 s)
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/Zdjęcia" has X-Request-ID "e5804fdc-8a1d-41ce-ba90-114e4720b427"
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/Dokumenty" has X-Request-ID "028bce3b-e531-4ea4-a3cd-9f49e98e7eb2"
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/" has X-Request-ID "b2169ba6-94ce-485d-a752-8a993cc2a1e4"
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/" has X-Request-ID "9061b263-7d03-4e83-bede-e3ab66b180b0"
[OCC::Folder::slotRunEtagJob Trying to check "https://example.domain.com:45083/remote.php/dav/files/maciek/Zdjęcia" for changes via ETag check. (time since last sync: 302 s)
[OCC::Folder::slotRunEtagJob Trying to check "https://example.domain.com:45083/remote.php/dav/files/maciek/Dokumenty" for changes via ETag check. (time since last sync: 299 s)
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/Zdjęcia" has X-Request-ID "a3c92206-5bd2-4b20-a900-e771dd64c37d"
[OCC::Account::slotHandleSslErrors "SSL-Errors happened for url \"https://example.domain.com:45083/remote.php/dav/files/maciek/Zdjęcia\" \tError in QSslCertificate(\"3\", \"bd:fa:64:1e:eb:e7:50:03\", \"zuyf5JZCeCpjF40/xr/Wiw==\", (\"QoolBox\"), (\"QoolBox\"), QMap(), QDateTime(2018-10-01 03:56:42.000 UTC Qt::TimeSpec(UTC)), QDateTime(2028-09-28 03:56:42.000 UTC Qt::TimeSpec(UTC))) : \"The host name did not match any of the valid hosts for this certificate\" ( \"The host name did not match any of the valid hosts for this certificate\" ) \n \tError in QSslCertificate(\"3\", \"bd:fa:64:1e:eb:e7:50:03\", \"zuyf5JZCeCpjF40/xr/Wiw==\", (\"QoolBox\"), (\"QoolBox\"), QMap(), QDateTime(2018-10-01 03:56:42.000 UTC Qt::TimeSpec(UTC)), QDateTime(2028-09-28 03:56:42.000 UTC Qt::TimeSpec(UTC))) : \"The certificate is self-signed, and untrusted\" ( \"The certificate is self-signed, and untrusted\" ) \n " Certs are known and trusted! This is not an actual error.
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/Dokumenty" has X-Request-ID "7dcb4719-c39f-4e75-b679-bc76d3197f50"
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/" has X-Request-ID "5343210a-5428-4b34-a387-ef11a5067f16"
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/" has X-Request-ID "62317e97-3cb3-4d5e-a81b-d11e69577f12"
[OCC::Folder::slotRunEtagJob Trying to check "https://example.domain.com:45083/remote.php/dav/files/maciek/Zdjęcia" for changes via ETag check. (time since last sync: 332 s)
[OCC::Folder::slotRunEtagJob Trying to check "https://example.domain.com:45083/remote.php/dav/files/maciek/Dokumenty" for changes via ETag check. (time since last sync: 329 s)
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/Zdjęcia" has X-Request-ID "66b17058-16ae-442e-b1fd-dea898d06cc8"
[OCC::AccessManager::createRequest 6 "PROPFIND" "https://example.domain.com:45083/remote.php/dav/files/maciek/Dokumenty" has X-Request-ID "1f0d4c0d-e9f4-4134-9cc0-1b37bb47fcf6"
