My nextcloud was lagging so i started debugging by disabling all plugins from admin, as a result i got maintenance mod window.
I did the following:
- changed config/config.php to maintenace => false
- occ maintenance:mode --off (Maintenance mode already disabled)
- occ maintenance:repair
Output
- Repair MySQL collation
- All tables already have the correct collation → nothing to do
- Repair mime types
- Clean tags and favorites
- 0 tags of deleted users have been removed.
- 0 tags for delete files have been removed.
- 0 tag entries for deleted tags have been removed.
- 0 tags with no entries have been removed.
- Repair invalid shares
- Move .step file of updater to backup location
- .step file exists
- .step-previous-update removed
- .step file moved to .step-previous-update
- Add move avatar background job
- Repair step already executed
- Add preview cleanup background jobs
- Migrate oauth2_clients table to nextcloud schema
- Update the oauth2_access_tokens table schema.
- Update the oauth2_clients table schema.
- Fix potential broken mount points
- No mounts updated
- Repair language codes
- Install new core bundle components
- Add log rotate job
- Clear frontend caches
- Image cache cleared
- SCSS cache cleared
- JS cache cleared
- Clear every generated avatar on major updates
- Add preview background cleanup job
- Queue a one-time job to cleanup old backups of the updater
- Cleanup invalid photocache files for carddav
- Add background job to cleanup login flow v2 tokens
- Remove potentially over exposing share links
- No need to remove link shares.
- Clear access cache of projects
- Reset generated avatar flag
- Keep legacy encryption enabled
- Check encryption key format
- Remove old dashboard app config data
- Add job to cleanup the bruteforce entries
- Queue a one-time job to check for user uploaded certificates
- Repair DAV shares
- Add background job to set the lookup server share state for users
- Fix component of birthday calendars
- 3 birthday calendars updated.
- Regenerating birthday calendars to use new icons and fix old birthday events without year
- Fix broken values of calendar objects
0 [->--------------------------] - Registering building of calendar search index as background job
- Register building of social profile search index as background job
- Registering background jobs to update cache for webcal calendars
- Added 0 background jobs to update webcal calendars
- Registering building of calendar reminder index as background job
- Clean up orphan event and contact data
- 0 events without a calendar have been cleaned up
- 0 properties without an events have been cleaned up
- 0 changes without a calendar have been cleaned up
- 0 cached events without a calendar subscription have been cleaned up
- 0 changes without a calendar subscription have been cleaned up
- 0 contacts without an addressbook have been cleaned up
- 0 properties without a contact have been cleaned up
- 0 changes without an addressbook have been cleaned up
- Remove activity entries of private events
- Removed 0 activity entries
- Clean up old calendar subscriptions from deleted users that were not cleaned-up
0 [----->----------------------]- 0 calendar subscriptions without an user have been cleaned up
- Update OAuth token expiration times
- Add background job to check for backup codes
- Populating added database structures for workflows
- Enabled debug => true (Nothing in logs)
- Restarted apache2
- Restarted instance
- Tried other browser/pc (no cache issue)
Despite all of above i still get maintenance window. what am i missing ?
