Hello together
I use collabora/code for my private Nextcloud installation. It works well.
The update also works well. I’m just doing that:
docker pull collabora/code
docker stop <container-name> && docker rm <container-name>
docker run collabora/code <some options>
My problem is now: All documents that are open during the update will not be saved. Can I trigger it by hand somehow? For example, OnlyOffice solved that:
# Due to the operational characteristic, Document Server saves a document only
# after the document has been closed by all the users who edited it. To avoid data loss,
# you must forcefully disconnect the Document Server users when you need to stop
# Document Server in cases of the application update, server reboot etc.
docker exec onlyoffice documentserver-prepare4shutdown.sh
docker stop onlyoffice
Is this also possible with Collabora? If not, how do you solve it?
Thanks,
Markus
