State token problems
    • 31.0.4
    • Debian 12 with Docker Compose
    • Nginx Proxy Manager - Version 2.12.3
    • When enabling default encryption module
    • Nextcloud AIO
Hey,
I’m new here.
So my problem is that when I enable the default encryption module and want to connect a new or existing account to an nextcloud app i have state token erros. Also the apps every time tells me that the encryption keys are note initalized and I should log out and log in again.
I have already reinstalled my whole instance but nothing helps.
I cheked the config and the overwriteprotocol and the other settings are set like they should set.
  1. Install defalut encyption module
  2. Enable server side encryption
  3. Try to log in with an existing or new NC user to an Nextcloud App (not web-app)
Nextcloud.log file
Error core OC\Authentication\Exceptions\InvalidTokenException: Token does not exist: token does not exist at 2025-04-27T13:29:38+00:00 .../Authentication/Token/PublicKeyTokenProvider.php line 165 0. .../Token/PublicKeyTokenProvider.php line 232 OC\Authentication\Token\PublicKeyTokenProvider->getToken("*** sensitive parameters replaced ***") 1. .../TTransactional.php line 45 OC\Authentication\Token\PublicKeyTokenProvider->OC\Authentication\Token\{closure}("*** sensitive paramet ... *") 2. .../Token/PublicKeyTokenProvider.php line 231 OC\Authentication\Token\PublicKeyTokenProvider->atomic(Closure {}, OC\DB\ConnectionAdapter {}) 3. .../Authentication/Token/Manager.php line 155 OC\Authentication\Token\PublicKeyTokenProvider->renewSessionToken( "*** sensitive parameters replaced ***", "0622c622f21dd750ef98deb0481ff2d1" ) 4. lib/private/User/Session.php line 883 OC\Authentication\Token\Manager->renewSessionToken( "*** sensitive parameters replaced ***", "0622c622f21dd750ef98deb0481ff2d1" ) 5. lib/base.php line 1107 OC\User\Session->loginWithCookie("*** sensitive parameters replaced ***") 6. lib/base.php line 1014 OC::handleLogin(OC\AppFramework\Http\Request {}) 7. index.php line 24 OC::handleRequest( ) Caused by OCP\AppFramework\Db\DoesNotExistException: token does not exist at .../Authentication/Token/PublicKeyTokenMapper.php line 81 0. .../Token/PublicKeyTokenProvider.php line 157 OC\Authentication\Token\PublicKeyTokenMapper->getToken("*** sensitive parameters replaced ***") 1. .../Token/PublicKeyTokenProvider.php line 232 OC\Authentication\Token\PublicKeyTokenProvider->getToken("*** sensitive parameters replaced ***") 2. .../TTransactional.php line 45 OC\Authentication\Token\PublicKeyTokenProvider->OC\Authentication\Token\{closure}("*** sensitive paramet ... *") 3. .../Token/PublicKeyTokenProvider.php line 231 OC\Authentication\Token\PublicKeyTokenProvider->atomic(Closure {}, OC\DB\ConnectionAdapter {}) 4. .../Authentication/Token/Manager.php line 155 OC\Authentication\Token\PublicKeyTokenProvider->renewSessionToken( "*** sensitive parameters replaced ***", "0622c622f21dd750ef98deb0481ff2d1" ) 5. lib/private/User/Session.php line 883 OC\Authentication\Token\Manager->renewSessionToken( "*** sensitive parameters replaced ***", "0622c622f21dd750ef98deb0481ff2d1" ) 6. lib/base.php line 1107 OC\User\Session->loginWithCookie("*** sensitive parameters replaced ***") 7. lib/base.php line 1014 OC::handleLogin(OC\AppFramework\Http\Request {}) 8. index.php line 24 OC::handleRequest( )
Before troubleshooting much further, can you confirm you have Asset Caching off in in NPM?
Yes, it is off
I’m having the same problem. I’ve seen posts saying it’s a bug under investigation.
Same issue here.
Same. Cannot log in on my iOS devices at all.
