example
longer
example
here
Nextcloud version (eg, 20.0.5): latest
Operating system and version (eg, Ubuntu 20.04): ubuntu
Apache or nginx version (eg, Apache 2.4.25): latest apache
PHP version (eg, 7.4): latest ubuntu
- Certificate expired
- Renewed it manually since no automation seems to had worked
- No ssl is shown working, very frustrating while new ssl seems to be made by certbot yet somehow snap does not replaces it.
PASTE HERE
PASTE HERE
PASTE HERE
