I need some help. My knowledge of SSL Certs is very limited. I have successfully installed NEXTCLOUD 12.0.5 using the Nextcloud VM. I have 2 domains one for Nextcloud and the other for Collabora. I have opened both port 80 and Port 443 and I have verified that they are open. The SSL Cert I am using is from Lets Encrypt. During the Nextcloud VM setup that is what they recommended so the Configuration script auto setup the lets encrypt SSL form me. I am planning on running both Nextcloud and Collabora from the same server it lookk like the Nextcloud VM allows it. When I go and run the script to setup Collabora it goes through but when gets to the SSL part it errors with the below error. I am stuck right now. Sp any help is appericated.
Failed authorization procedure. office.coldwolf.info (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: The key authorization file from the server did not match this challenge [x4gyiYoPNvDTSCNf1wSv9feBwdz1T_hqXNDCKcPbHoE.chi-WDZesVf1rkqKiqEsryE7nk_eMHdjX4tJM293XME] != [ACME client standalone challenge solver]
IMPORTANT NOTES:
The following errors were reported by the server:
Domain: office.coldwolf.info
Type: unauthorized
Detail: The key authorization file from the server did not match
this challenge
To fix these errors, please make sure that your domain name was
entered correctly and the DNS A/AAAA record(s) for that domain
contain(s) the right IP address.
It seems like no certs were generated, please report this issue here: https://github.com/nextcloud/vm/issues
