Sorry to hear youâre facing problems
help.nextcloud.com is for home/non-enterprise users. If youâre running a business, paid support can be accessed via portal.nextcloud.com where we can ensure your business keeps running smoothly.
example
longer
example
here
Some or all of the below information will be requested if it isnât supplied; for fastest response please provide as much as you can
The issue you are facing: Went to log in to my nextcloud via browser and got a connection refused error and on the app on my phone it says there was an ssl error i sshed into the pi and manually updated it and it didnt fix it i also tried connecting directly as i use a dns service but that wasnt the issue either it still refuses when i ssh into it everything appears normal i have no isses so im kind of lost as to what is going on.
Launching nc-info
Gathering informationâŚ
NextCloudPi version v0.66.1
NextCloudPi image NextCloudPi_10-23-18
distribution Raspbian GNU/Linux 9 \n \l
automount yes
USB devices none
datadir /var/www/nextcloud/data
data in SD yes
data filesystem ext2/ext3
data disk usage 14G/30G
rootfs usage 14G/30G
swapfile /var/swap
dbdir /var/lib/mysql
Nextcloud check ok
Nextcloud version 14.0.3.0
HTTPD service down
PHP service up
MariaDB service up
Redis service up
Postfix service up
internet check ok
port check 80 closed
port check 443 closed
IP 192.168.1.143
gateway 192.168.1.1
interface eth0
certificates ******
NAT loopback yes
uptime 15min
Launching letsencrypt
Saving debug log to /var/log/letsencrypt/letsencrypt.log
Plugins selected: Authenticator webroot, Installer None
Cert not yet due for renewal
Keeping the existing certificate
This seems like it might be it but idk what to do about this:
[Mon Nov 05 06:25:02.111150 2018] [ssl:warn] [pid 974:tid 1995587984] AH01882: Init: this version of mod_ssl was compiled against a newer library (OpenSSL 1.1.0h 27 Mar 2018, version currently loaded is OpenSSL 1.1.0f 25 May 2017) - may result in undefined or erroneous behavior
[Mon Nov 05 06:25:02.120215 2018] [ssl:warn] [pid 974:tid 1995587984] AH01909: localhost:4443:0 server certificate does NOT include an ID which matches the server name
Is this the first time youâve seen this error? (Y/N): Yes
