I have installed 12.0.2 in a shared web host. I have a SSL cert installed, which is working.
When I try to enable an app, I get this error message:
“cURL error 77: Problem with the SSL CA cert (path? access rights?)”
What should I do?
Thanks.
What should I do?
Thanks.
Does your uploaded cert contain a full chain, cross-signed if required?
Tbh I don’t know. There is a “domain.crt” file and a “domain.ca-bundle”. Would those be them?
Probably OK,
Can you restart Apache? service httpd restart
or service apache2 restart
Try it again.
I can’t. When I log trough SSH I’m in jail. The SSL is working in nextcloud and other webs on the same domain. I got that error when I try to enable any app.
Sure I read that. I understand however that updating Apache and not restarting can cause this. Maybe.
