Dear all I am not sure if this is right place for this topic, but I try it.
I am trying convert my SQLite database to MariaDB.
So I was going according this manual
https://docs.nextcloud.com/server/20/admin_manual/configuration_database/db_conversion.html
There are mentioned some Inconvertible tables which should be ignored, but in my case I have all different tables regarding to app Radio and PhoneSync. (see bellow)
For me is interesting only Radio because I am this using, but I do not know why is there PhoneSync because after this command I removed app PhoneSync from my nextcloud.
My question is can I continue in conversion database when is got this warning? Will work me Radio app (or PhoneSync) when I will continue with the conversion in MariaDB? Or what I should to do fix this warning?
Thanks
What is the database password?
Creating schema in new database
The following tables will not be converted:
oc_ocsms_config
oc_ocsms_conversation_read_states
oc_ocsms_sendmessage_queue
oc_ocsms_smsdatas
oc_ocsms_user_datas
oc_radio_stations
Continue with the conversion (y/n)? [n]
