I have updated my Nextcloud from 15.0.5 to 15.0.7 and then i get a message in the tab overview in the WebUI like “utf8_mb4 not activated but needed for smileys for help look into our documentations” then i’ve look there https://docs.nextcloud.com/server/15/admin_manual/configuration_database/mysql_4byte_support.html and make that:
[mysqld]
innodb_file_per_table=1
have I added in my /etc/mysql/mariadb.cnf and to my /etc/mysql/my.cnf
then i typed this in my mysql:
ALTER DATABASE nextcloud CHARACTER SET utf8mb4 COLLATE utf8mb4_general_ci;
then have I done this:
sudo -u www-data php occ config:system:set mysql.utf8mb4 --type boolean --value=“true”
sudo -u www-data php occ maintenance:repair
and the other sql commands on this site.
Nextcloud version (eg, 15.0.7):
Operating system and version (eg, Raspbian 9):
PHP version (eg, 7.3.3):
The issue who I facing is:
Every time i will do sudo -u www-data php occ files:scan -all I get this error:
SQLSTATE[42000]: Syntax error or access violation: 1253 COLLATION ‘utf8mb4_
general_ci’ is not valid for CHARACTER SET ‘utf8’
Yes is the first time is this error.
I think it’s a SQL problem because if I delete this entry ‘mysql.utf8mb4’ => true, in my config.php the error is away.
I am also facing the same error on my Nextcloud setup and unable to see the users in gui.
I checked the tables in nextcloud database oc_addressbooks has 4 columns with varchar(255) is that the reason?
I get following error while doing maintenance repair:
Nextcloud is in maintenance mode - no apps have been loaded
Repair MySQL collation
Change row format for oc_addressbooks …
Change collation for oc_addressbooks …
ERROR: An exception occurred while executing a query: SQLSTATE[HY000]: General error: 1709 Index column size too large. The maximum column size is 767 bytes.
$ occ user:list
In ExceptionConverter.php line 114:
An exception occurred while executing a query: SQLSTATE[42000]: Syntax error or access violation: 1253 COLLATION
'utf8mb4_general_ci' is not valid for CHARACTER SET 'utf8mb3
