- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
33.0.5
Debian 12
Apache
Apache
- PHP version (e.g, 8.3):
8.2
Yes
No idea
Archive
No
When trying to share a file with another Nextcloud user, the wheel starts spinning but never any result is returned. An (incomplete) SQL (PostgreSQL) error about a missing email column can be found in nextcloud.log:
An exception occurred while executing a query: SQLSTATE[42703]: Undefined column: 7 ERROR: column "email" does not exist\nLINE 1: …"configkey" = ‘email’) WHERE ("uid" ILIKE $1) OR ("email" IL…\n
Select a file in Nextcloud
On the sharing tab, when I click in the Internal Sharing field, the names of some recently used users is shown.
As I want to share with another user, I start typing its name in the field
I get a spinning wheel, but no results are returned
{"reqId":"EHXSdZgcA6k5bwENu2gy","level":3,"time":"June 03, 2026 09:14:03","remoteAddr":"192.168.0.10","user":"myusername","app":"no app in context","method":"GET","url":"/ocs/v2.php/apps/files_sharing/api/v1/sharees?format=json&itemType=file&search=firstname+lastname&lookup=false&perPage=25&shareType%5B%5D=0&shareType%5B%5D=1&shareType%5B%5D=7&shareType%5B%5D=10&shareType%5B%5D=8&shareType%5B%5D=12&shareType%5B%5D=15","scriptName":"/ocs/v2.php","message":"An exception occurred while executing a query: SQLSTATE[42703]: Undefined column: 7 ERROR: column \"email\" does not exist\nLINE 1: ...\"configkey\" = 'email') WHERE (\"uid\" ILIKE $1) OR (\"email\" IL...\n ^","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:151.0) Gecko/20100101 Firefox/151.0","version":"33.0.5.1","exception":{"Exception":"OC\\DB\\Exceptions\\DbalException","Message":"An exception occurred while executing a query: SQLSTATE[42703]: Undefined column: 7 ERROR: column \"email\" does not exist\nLINE 1: ...\"configkey\" = 'email') WHERE (\"uid\" ILIKE $1) OR (\"email\" IL...\n ^","Code":7,"Trace":[{"file":"/var/www/nextcloud/lib/private/DB/ConnectionAdapter.php","line":53,"function":"wrap","class":"OC\\DB\\Exceptions\\DbalException","type":"::"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":268,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/var/www/nextcloud/apps/guests/lib/UserBackend.php","line":241,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":277,"function":"getDisplayNames","class":"OCA\\Guests\\UserBackend","type":"->"},{"file":"/var/www/nextcloud/lib/private/Collaboration/Collaborators/UserPlugin.php","line":52,"function":"searchDisplayName","class":"OC\\User\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Collaboration/Collaborators/Search.php","line":47,"function":"search","class":"OC\\Collaboration\\Collaborators\\UserPlugin","type":"->"},{"file":"/var/www/nextcloud/apps/files_sharing/lib/Controller/ShareesAPIController.php","line":186,"function":"search","class":"OC\\Collaboration\\Collaborators\\Search","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":205,"function":"search","class":"OCA\\Files_Sharing\\Controller\\ShareesAPIController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/ocs/v1.php","line":61,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/ocs/v2.php","line":8,"args":["/var/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/DB/Exceptions/DbalException.php","Line":56,"Previous":{"Exception":"Doctrine\\DBAL\\Exception\\InvalidFieldNameException","Message":"An exception occurred while executing a query: SQLSTATE[42703]: Undefined column: 7 ERROR: column \"email\" does not exist\nLINE 1: ...\"configkey\" = 'email') WHERE (\"uid\" ILIKE $1) OR (\"email\" IL...\n ^","Code":7,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1976,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\PostgreSQL\\ExceptionConverter","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1918,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1111,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":420,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/ConnectionAdapter.php","line":50,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":268,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/var/www/nextcloud/apps/guests/lib/UserBackend.php","line":241,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":277,"function":"getDisplayNames","class":"OCA\\Guests\\UserBackend","type":"->"},{"file":"/var/www/nextcloud/lib/private/Collaboration/Collaborators/UserPlugin.php","line":52,"function":"searchDisplayName","class":"OC\\User\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Collaboration/Collaborators/Search.php","line":47,"function":"search","class":"OC\\Collaboration\\Collaborators\\UserPlugin","type":"->"},{"file":"/var/www/nextcloud/apps/files_sharing/lib/Controller/ShareesAPIController.php","line":186,"function":"search","class":"OC\\Collaboration\\Collaborators\\Search","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":205,"function":"search","class":"OCA\\Files_Sharing\\Controller\\ShareesAPIController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/ocs/v1.php","line":61,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/ocs/v2.php","line":8,"args":["/var/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/PostgreSQL/ExceptionConverter.php","Line":68,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[42703]: Undefined column: 7 ERROR: column \"email\" does not exist\nLINE 1: ...\"configkey\" = 'email') WHERE (\"uid\" ILIKE $1) OR (\"email\" IL...\n ^","Code":7,"Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":132,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1104,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":420,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/ConnectionAdapter.php","line":50,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":268,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/var/www/nextcloud/apps/guests/lib/UserBackend.php","line":241,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":277,"function":"getDisplayNames","class":"OCA\\Guests\\UserBackend","type":"->"},{"file":"/var/www/nextcloud/lib/private/Collaboration/Collaborators/UserPlugin.php","line":52,"function":"searchDisplayName","class":"OC\\User\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Collaboration/Collaborators/Search.php","line":47,"function":"search","class":"OC\\Collaboration\\Collaborators\\UserPlugin","type":"->"},{"file":"/var/www/nextcloud/apps/files_sharing/lib/Controller/ShareesAPIController.php","line":186,"function":"search","class":"OC\\Collaboration\\Collaborators\\Search","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":205,"function":"search","class":"OCA\\Files_Sharing\\Controller\\ShareesAPIController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/ocs/v1.php","line":61,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/ocs/v2.php","line":8,"args":["/var/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":24,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[42703]: Undefined column: 7 ERROR: column \"email\" does not exist\nLINE 1: ...\"configkey\" = 'email') WHERE (\"uid\" ILIKE $1) OR (\"email\" IL...\n ^","Code":"42703","Trace":[{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":130,"function":"execute","class":"PDOStatement","type":"->"},{"file":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php","line":1104,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/Connection.php","line":420,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/ConnectionAdapter.php","line":50,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->"},{"file":"/var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php","line":268,"function":"executeQuery","class":"OC\\DB\\ConnectionAdapter","type":"->"},{"file":"/var/www/nextcloud/apps/guests/lib/UserBackend.php","line":241,"function":"executeQuery","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->"},{"file":"/var/www/nextcloud/lib/private/User/Manager.php","line":277,"function":"getDisplayNames","class":"OCA\\Guests\\UserBackend","type":"->"},{"file":"/var/www/nextcloud/lib/private/Collaboration/Collaborators/UserPlugin.php","line":52,"function":"searchDisplayName","class":"OC\\User\\Manager","type":"->"},{"file":"/var/www/nextcloud/lib/private/Collaboration/Collaborators/Search.php","line":47,"function":"search","class":"OC\\Collaboration\\Collaborators\\UserPlugin","type":"->"},{"file":"/var/www/nextcloud/apps/files_sharing/lib/Controller/ShareesAPIController.php","line":186,"function":"search","class":"OC\\Collaboration\\Collaborators\\Search","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":205,"function":"search","class":"OCA\\Files_Sharing\\Controller\\ShareesAPIController","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/ocs/v1.php","line":61,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/ocs/v2.php","line":8,"args":["/var/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":130}}},"message":"An exception occurred while executing a query: SQLSTATE[42703]: Undefined column: 7 ERROR: column \"email\" does not exist\nLINE 1: ...\"configkey\" = 'email') WHERE (\"uid\" ILIKE $1) OR (\"email\" IL...\n ^","exception":"{\"class\":\"OC\\DB\\Exceptions\\DbalException\",\"message\":\"An exception occurred while executing a query: SQLSTATE[42703]: Undefined column: 7 ERROR: column \\\"email\\\" does not exist\\nLINE 1: ...\\\"configkey\\\" = 'email') WHERE (\\\"uid\\\" ILIKE $1) OR (\\\"email\\\" IL...\\n ^\",\"code\":7,\"file\":\"/var/www/nextcloud/lib/private/DB/Exceptions/DbalException.php:56\",\"trace\":\"#0 /var/www/nextcloud/lib/private/DB/ConnectionAdapter.php(53): OC\\DB\\Exceptions\\DbalException::wrap()\\n#1 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(268): OC\\DB\\ConnectionAdapter->executeQuery()\\n#2 /var/www/nextcloud/apps/guests/lib/UserBackend.php(241): OC\\DB\\QueryBuilder\\QueryBuilder->executeQuery()\\n#3 /var/www/nextcloud/lib/private/User/Manager.php(277): OCA\\Guests\\UserBackend->getDisplayNames()\\n#4 /var/www/nextcloud/lib/private/Collaboration/Collaborators/UserPlugin.php(52): OC\\User\\Manager->searchDisplayName()\\n#5 /var/www/nextcloud/lib/private/Collaboration/Collaborators/Search.php(47): OC\\Collaboration\\Collaborators\\UserPlugin->search()\\n#6 /var/www/nextcloud/apps/files_sharing/lib/Controller/ShareesAPIController.php(186): OC\\Collaboration\\Collaborators\\Search->search()\\n#7 /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php(205): OCA\\Files_Sharing\\Controller\\ShareesAPIController->search()\\n#8 /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php(118): OC\\AppFramework\\Http\\Dispatcher->executeController()\\n#9 /var/www/nextcloud/lib/private/AppFramework/App.php(153): OC\\AppFramework\\Http\\Dispatcher->dispatch()\\n#10 /var/www/nextcloud/lib/private/Route/Router.php(321): OC\\AppFramework\\App::main()\\n#11 /var/www/nextcloud/ocs/v1.php(61): OC\\Route\\Router->match()\\n#12 /var/www/nextcloud/ocs/v2.php(8): require_once('...')\\n#13 {main}\",\"previous\":{\"class\":\"Doctrine\\DBAL\\Exception\\InvalidFieldNameException\",\"message\":\"An exception occurred while executing a query: SQLSTATE[42703]: Undefined column: 7 ERROR: column \\\"email\\\" does not exist\\nLINE 1: ...\\\"configkey\\\" = 'email') WHERE (\\\"uid\\\" ILIKE $1) OR (\\\"email\\\" IL...\\n ^\",\"code\":7,\"file\":\"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/API/PostgreSQL/ExceptionConverter.php:68\",\"trace\":\"#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1976): Doctrine\\DBAL\\Driver\\API\\PostgreSQL\\ExceptionConverter->convert()\\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1918): Doctrine\\DBAL\\Connection->handleDriverException()\\n#2 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1111): Doctrine\\DBAL\\Connection->convertExceptionDuringQuery()\\n#3 /var/www/nextcloud/lib/private/DB/Connection.php(420): Doctrine\\DBAL\\Connection->executeQuery()\\n#4 /var/www/nextcloud/lib/private/DB/ConnectionAdapter.php(50): OC\\DB\\Connection->executeQuery()\\n#5 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(268): OC\\DB\\ConnectionAdapter->executeQuery()\\n#6 /var/www/nextcloud/apps/guests/lib/UserBackend.php(241): OC\\DB\\QueryBuilder\\QueryBuilder->executeQuery()\\n#7 /var/www/nextcloud/lib/private/User/Manager.php(277): OCA\\Guests\\UserBackend->getDisplayNames()\\n#8 /var/www/nextcloud/lib/private/Collaboration/Collaborators/UserPlugin.php(52): OC\\User\\Manager->searchDisplayName()\\n#9 /var/www/nextcloud/lib/private/Collaboration/Collaborators/Search.php(47): OC\\Collaboration\\Collaborators\\UserPlugin->search()\\n#10 /var/www/nextcloud/apps/files_sharing/lib/Controller/ShareesAPIController.php(186): OC\\Collaboration\\Collaborators\\Search->search()\\n#11 /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php(205): OCA\\Files_Sharing\\Controller\\ShareesAPIController->search()\\n#12 /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php(118): OC\\AppFramework\\Http\\Dispatcher->executeController()\\n#13 /var/www/nextcloud/lib/private/AppFramework/App.php(153): OC\\AppFramework\\Http\\Dispatcher->dispatch()\\n#14 /var/www/nextcloud/lib/private/Route/Router.php(321): OC\\AppFramework\\App::main()\\n#15 /var/www/nextcloud/ocs/v1.php(61): OC\\Route\\Router->match()\\n#16 /var/www/nextcloud/ocs/v2.php(8): require_once('...')\\n#17 {main}\",\"previous\":{\"class\":\"Doctrine\\DBAL\\Driver\\PDO\\Exception\",\"message\":\"SQLSTATE[42703]: Undefined column: 7 ERROR: column \\\"email\\\" does not exist\\nLINE 1: ...\\\"configkey\\\" = 'email') WHERE (\\\"uid\\\" ILIKE $1) OR (\\\"email\\\" IL...\\n ^\",\"code\":7,\"file\":\"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php:24\",\"trace\":\"#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php(132): Doctrine\\DBAL\\Driver\\PDO\\Exception::new()\\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1104): Doctrine\\DBAL\\Driver\\PDO\\Statement->execute()\\n#2 /var/www/nextcloud/lib/private/DB/Connection.php(420): Doctrine\\DBAL\\Connection->executeQuery()\\n#3 /var/www/nextcloud/lib/private/DB/ConnectionAdapter.php(50): OC\\DB\\Connection->executeQuery()\\n#4 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(268): OC\\DB\\ConnectionAdapter->executeQuery()\\n#5 /var/www/nextcloud/apps/guests/lib/UserBackend.php(241): OC\\DB\\QueryBuilder\\QueryBuilder->executeQuery()\\n#6 /var/www/nextcloud/lib/private/User/Manager.php(277): OCA\\Guests\\UserBackend->getDisplayNames()\\n#7 /var/www/nextcloud/lib/private/Collaboration/Collaborators/UserPlugin.php(52): OC\\User\\Manager->searchDisplayName()\\n#8 /var/www/nextcloud/lib/private/Collaboration/Collaborators/Search.php(47): OC\\Collaboration\\Collaborators\\UserPlugin->search()\\n#9 /var/www/nextcloud/apps/files_sharing/lib/Controller/ShareesAPIController.php(186): OC\\Collaboration\\Collaborators\\Search->search()\\n#10 /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php(205): OCA\\Files_Sharing\\Controller\\ShareesAPIController->search()\\n#11 /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php(118): OC\\AppFramework\\Http\\Dispatcher->executeController()\\n#12 /var/www/nextcloud/lib/private/AppFramework/App.php(153): OC\\AppFramework\\Http\\Dispatcher->dispatch()\\n#13 /var/www/nextcloud/lib/private/Route/Router.php(321): OC\\AppFramework\\App::main()\\n#14 /var/www/nextcloud/ocs/v1.php(61): OC\\Route\\Router->match()\\n#15 /var/www/nextcloud/ocs/v2.php(8): require_once('...')\\n#16 {main}\",\"previous\":{\"class\":\"PDOException\",\"message\":\"SQLSTATE[42703]: Undefined column: 7 ERROR: column \\\"email\\\" does not exist\\nLINE 1: ...\\\"configkey\\\" = 'email') WHERE (\\\"uid\\\" ILIKE $1) OR (\\\"email\\\" IL...\\n ^\",\"code\":\"42703\",\"file\":\"/var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php:130\",\"trace\":\"#0 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php(130): PDOStatement->execute()\\n#1 /var/www/nextcloud/3rdparty/doctrine/dbal/src/Connection.php(1104): Doctrine\\DBAL\\Driver\\PDO\\Statement->execute()\\n#2 /var/www/nextcloud/lib/private/DB/Connection.php(420): Doctrine\\DBAL\\Connection->executeQuery()\\n#3 /var/www/nextcloud/lib/private/DB/ConnectionAdapter.php(50): OC\\DB\\Connection->executeQuery()\\n#4 /var/www/nextcloud/lib/private/DB/QueryBuilder/QueryBuilder.php(268): OC\\DB\\ConnectionAdapter->executeQuery()\\n#5 /var/www/nextcloud/apps/guests/lib/UserBackend.php(241): OC\\DB\\QueryBuilder\\QueryBuilder->executeQuery()\\n#6 /var/www/nextcloud/lib/private/User/Manager.php(277): OCA\\Guests\\UserBackend->getDisplayNames()\\n#7 /var/www/nextcloud/lib/private/Collaboration/Collaborators/UserPlugin.php(52): OC\\User\\Manager->searchDisplayName()\\n#8 /var/www/nextcloud/lib/private/Collaboration/Collaborators/Search.php(47): OC\\Collaboration\\Collaborators\\UserPlugin->search()\\n#9 /var/www/nextcloud/apps/files_sharing/lib/Controller/ShareesAPIController.php(186): OC\\Collaboration\\Collaborators\\Search->search()\\n#10 /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php(205): OCA\\Files_Sharing\\Controller\\ShareesAPIController->search()\\n#11 /var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php(118): OC\\AppFramework\\Http\\Dispatcher->executeController()\\n#12 /var/www/nextcloud/lib/private/AppFramework/App.php(153): OC\\AppFramework\\Http\\Dispatcher->dispatch()\\n#13 /var/www/nextcloud/lib/private/Route/Router.php(321): OC\\AppFramework\\App::main()\\n#14 /var/www/nextcloud/ocs/v1.php(61): OC\\Route\\Router->match()\\n#15 /var/www/nextcloud/ocs/v2.php(8): require_once('...')\\n#16 {main}\"}}}}","CustomMessage":"An exception occurred while executing a query: SQLSTATE[42703]: Undefined column: 7 ERROR: column \"email\" does not exist\nLINE 1: ...\"configkey\" = 'email') WHERE (\"uid\" ILIKE $1) OR (\"email\" IL...\n ^"}}
PASTE
PASTE HERE
"192.168.0.1"
"dbtype": "pgsql",
"debug": false,
"version": "33.0.5.1",
"overwrite.cli.url": "https:\/\/cloud.example.com",
"dbport": "",
"ldapIgnoreNamingRules": false,
"htaccess.RewriteBase": "\/",
"redis": {
"port": 0,
"timeout": 0
"overwritehost": "cloud.example.com",
"overwriteprotocol": "https",
"skeletondirectory": "",
"twofactor_enforced": "true",
"admin"
"mail_smtpmode": "sendmail",
"mail_sendmailmode": "smtp",
"mail_smtpport": "25",
"default_phone_region": "BE",
"log_type": "file",
"logfile": "\/var\/www\/nextcloud\/data\/nextcloud.log",
"logdateformat": "F d, Y H:i:s",
"log.condition": {
"apps": [
"admin_audit"
"loglevel": 2,
"theme": "",
"app_install_overwrite": [
"unsplash",
"files_retention",
"ransomware_detection",
"files_readmemd",
"bruteforcesettings",
"files_antivirus",
"talk_matterbridge",
"impersonate",
"files_markdown",
"oidc_login"
"memories.exiftool": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/exiftool-amd64-glibc",
"memories.vod.path": "\/var\/www\/nextcloud\/apps\/memories\/bin-ext\/go-vod-amd64",
"allow_user_to_change_display_name": false,
"oidc_login_auto_redirect": false,
"oidc_login_provider_url": "https:\/\/auth.example.com\/realms\/bar\/",
"oidc_login_client_id": "nextcloud",
"oidc_login_client_secret": "foo",
"oidc_login_logout_url": "https:\/\/cloud.example.com\/apps\/oidc_login\/oidc",
"oidc_login_end_session_redirect": true,
"oidc_login_default_quota": "32212254720",
"oidc_login_button_text": "Log in with Example.com account",
"oidc_login_hide_password_form": false,
"oidc_login_use_id_token": false,
"oidc_login_attributes": {
"id": "preferred_username",
"mail": "email",
"login_filter": "nextcloudGroups",
"groups": "nextcloudGroups",
"is_admin": "nextcloudAdmin"
"oidc_login_filter_allowed_values": [
"nextcloud"
"oidc_login_use_external_storage": false,
"oidc_login_scope": "openid profile email roles",
"oidc_login_proxy_ldap": false,
"oidc_login_disable_registration": false,
"oidc_login_redir_fallback": false,
"oidc_login_tls_verify": true,
"oidc_create_groups": false,
"oidc_login_webdav_enabled": true,
"oidc_login_password_authentication": false,
"oidc_login_public_key_caching_time": 86400,
"oidc_login_min_time_between_jwks_requests": 10,
"oidc_login_well_known_caching_time": 86400,
"oidc_login_skip_proxy": false,
"oidc_login_code_challenge_method": "",
"trashbin_retention_obligation": "auto,30",
"enabledPreviewProviders": [
"OC\\Preview\\Image",
"OC\\Preview\\HEIC",
"OC\\Preview\\TIFF",
"OC\\Preview\\Movie"
"files.chunked_upload.max_size": 104857600
- Use the
preformatted textformatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
