Hi together,
I had to setup a new image after a blackout, because the file system seemed to be currupted. After restoring my backup I’m failing to enable spDYN. I have tried it in the Web panel and in the terminal with ncp-config.
I have checked /etc/cron.d/spdnsupdater
10 * * * * root /usr/local/etc/spdnsupdater/spdnsUpdater.sh *******.*****.de xxxx-yyyy-zzzz >/dev/null 2>&1 (placeholders added)
Host update does not work. When I check in the dashboard of spdyn I can read only: The token for this host was created on 26.03.2021 at 21:52:31 o’clock but never used.
When I try to do in the terminal I get as response two brackets only
pi@nextcloudpi:~ $ sudo /usr/local/etc/spdnsupdater/spdnsUpdater.sh *******.*****.de xxxx-yyyy-zzzz
pi@nextcloudpi:~ $
I have tried it with the update token and with the move token. No change …
Does somebody has an idea? Thanks in advance!
I use a Rapberry Pi 2B.
NextCloudPi version v1.35.0
NextCloudPi image NextCloudPi_09-05-20
distribution Raspbian GNU/Linux 10 \n \l
automount yes
USB devices sda sdb
datadir /media/Cloud_NAS44/data
data in SD no
data filesystem btrfs
data disk usage 8.0G/58G
rootfs usage 2.2G/7.1G
swapfile /media/Backup/swap
dbdir /var/lib/mysql
Nextcloud check ok
Nextcloud version 20.0.4.0
HTTPD service up
PHP service up
MariaDB service up
Redis service up
Postfix service up
internet check ok
port check 80 open
port check 443 open
IP REMOVED SENSITIVE VALUE
gateway REMOVED SENSITIVE VALUE
interface eth0
certificates REMOVED SENSITIVE VALUE
NAT loopback no
uptime 11:32
