nginx access log, cleared, one settings request, pasted here:
::1 - - [13/Jan/2020:10:28:40 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 200 78 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML
, like Gecko) Chrome/79.0.3945.88 Safari/537.36"
::1 - - [13/Jan/2020:10:28:41 +0100] "GET /settings/user HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safa
ri/537.36"
::1 - - [13/Jan/2020:10:28:41 +0100] "GET / HTTP/1.1" 302 5 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Safari/537.36"
::1 - - [13/Jan/2020:10:28:41 +0100] "GET /apps/files/ HTTP/1.1" 200 10855 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/79.0.3945.88 Sa
fari/537.36"
::1 - - [13/Jan/2020:10:28:42 +0100] "GET /ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 200 78 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML
::1 - - [13/Jan/2020:10:28:43 +0100] "GET /index.php/apps/richdocuments/ajax/settings.php HTTP/1.1" 200 113 "-" "Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, l
nginx access_error_log: still empty after request.
nginx error_log: only recent restarts of the server, no problems mentioned.
php-fpm.log
[13-Jan-2020 08:19:26] NOTICE: [pool www] child 13352 exited with code 0 after 17323.286874 seconds from start
[13-Jan-2020 08:19:26] NOTICE: [pool www] child 2312 started
Nextcloud log:
{"reqId":"pk8XGroXsoKCsx3jiZg9","level":3,"time":"2020-01-13T10:41:50+01:00","remoteAddr":"127.0.0.1","user":"username","app":"index","method":"PUT","url":"\/index.php\/apps
\/notes\/api\/v0.2\/notes\/110763?","message":{"Exception":"OCP\\Lock\\LockedException","Message":"\"Notes\/Boeken 1.txt\" is locked","Code":0,"Trace":[{"file":"\/data\/WWW\
/nc.site.name\/htdocs\/lib\/private\/Files\/View.php","line":2050,"function":"lockPath","class":"OC\\Files\\View","type":"->","args":["\/username\/files\/Notes\/Boeken 1.txt
",1,"*** sensitive parameter replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Files\/View.php","line":1140,"function":"lockFile","class":"OC\\Files\
\View","type":"->","args":["\/username\/files\/Notes\/Boeken 1.txt",1]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Files\/View.php","line":994,"function":"bas
icOperation","class":"OC\\Files\\View","type":"->","args":["fopen","\/username\/files\/Notes\/Boeken 1.txt",["read"],"r"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/p
rivate\/Files\/Node\/File.php","line":108,"function":"fopen","class":"OC\\Files\\View","type":"->","args":["\/username\/files\/Notes\/Boeken 1.txt","r"]},{"file":"\/data\/WW
W\/nc.site.name\/htdocs\/apps\/ransomware_detection\/lib\/Analyzer\/EntropyAnalyzer.php","line":164,"function":"fopen","class":"OC\\Files\\Node\\File","type":"->","args":["r
"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/ransomware_detection\/lib\/Analyzer\/EntropyAnalyzer.php","line":105,"function":"calculateEntropyOfFile","class":"OCA\\
RansomwareDetection\\Analyzer\\EntropyAnalyzer","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"}]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/ransomware_dete
ction\/lib\/Monitor.php","line":450,"function":"analyze","class":"OCA\\RansomwareDetection\\Analyzer\\EntropyAnalyzer","type":"->","args":[{"__class__":"OC\\Files\\Node\\Fil
e"}]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/ransomware_detection\/lib\/Monitor.php","line":207,"function":"addFileOperation","class":"OCA\\RansomwareDetection\\M
onitor","type":"->","args":[["files\/Notes\/Boeken 1.txt"],{"__class__":"OC\\Files\\Node\\File"},3]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/ransomware_detection\/
lib\/StorageWrapper.php","line":257,"function":"analyze","class":"OCA\\RansomwareDetection\\Monitor","type":"->","args":[{"mountPoint":"\/username\/","cache":null,"scanner":
null,"watcher":null,"propagator":null,"updater":null,"__class__":"OCA\\RansomwareDetection\\StorageWrapper"},["files\/Notes\/Boeken 1.txt"],3]},{"file":"\/data\/WWW\/nc.site
.name\/htdocs\/apps\/ransomware_detection\/lib\/StorageWrapper.php","line":98,"function":"analyze","class":"OCA\\RansomwareDetection\\StorageWrapper","type":"->","args":[{"m
ountPoint":"\/username\/","cache":null,"scanner":null,"watcher":null,"propagator":null,"updater":null,"__class__":"OCA\\RansomwareDetection\\StorageWrapper"},["files\/Notes\
/Boeken 1.txt"],3]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/ransomware_protection\/lib\/StorageWrapper.php","line":252,"function":"file_put_contents","class":"OCA\
\RansomwareDetection\\StorageWrapper","type":"->","args":["files\/Notes\/Boeken 1.txt","*** sensitive parameter replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/l
ib\/private\/Files\/View.php","line":1158,"function":"file_put_contents","class":"OCA\\RansomwareProtection\\StorageWrapper","type":"->","args":["files\/Notes\/Boeken 1.txt"
,"*** sensitive parameter replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Files\/View.php","line":694,"function":"basicOperation","class":"OC\\File
s\\View","type":"->","args":["file_put_contents","\/username\/files\/Notes\/Boeken 1.txt",["update","write"],"*** sensitive parameter replaced ***"]},{"file":"\/data\/WWW\/n
c.site.name\/htdocs\/lib\/private\/Files\/Node\/File.php","line":66,"function":"file_put_contents","class":"OC\\Files\\View","type":"->","args":["\/username\/files\/Notes\/B
oeken 1.txt","*** sensitive parameter replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/notes\/lib\/Service\/NotesService.php","line":176,"function":"putCont
ent","class":"OC\\Files\\Node\\File","type":"->","args":["*** sensitive parameter replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/notes\/lib\/Controller\/N
otesApiController.php","line":177,"function":"update","class":"OCA\\Notes\\Service\\NotesService","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/da
ta\/WWW\/nc.site.name\/htdocs\/apps\/notes\/lib\/Controller\/NotesApiController.php","line":158,"function":"updateData","class":"OCA\\Notes\\Controller\\NotesApiController",
"type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/notes\/lib\/Controller\/Errors.php","line":22,"function":"OCA
\\Notes\\Controller\\{closure}","class":"OCA\\Notes\\Controller\\NotesApiController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/data\/WWW\/nc.s
ite.name\/htdocs\/apps\/notes\/lib\/Controller\/NotesApiController.php","line":159,"function":"respond","class":"OCA\\Notes\\Controller\\NotesApiController","type":"->","arg
s":[{"__class__":"Closure"}]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/AppFramework\/Http\/Dispatcher.php","line":170,"function":"update","class":"OCA\\Note
s\\Controller\\NotesApiController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/AppFramework\/Http
\/Dispatcher.php","line":99,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Notes\\Controller\\NotesApiCon
troller"},"update"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/AppFramework\/App.php","line":126,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispa
tcher","type":"->","args":[{"__class__":"OCA\\Notes\\Controller\\NotesApiController"},"update"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/AppFramework\/Rout
ing\/RouteActionHandler.php","line":47,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Notes\\Controller\\NotesApiController","update",{"__class_
_":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"id":"110763","_route":"notes.notes_api.update"}]},{"function":"__invoke","class":"OC\\AppFramework\\Routing\\Route
ActionHandler","type":"->","args":[{"id":"110763","_route":"notes.notes_api.update"}]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Route\/Router.php","line":29
7,"function":"call_user_func","args":[{"__class__":"OC\\AppFramework\\Routing\\RouteActionHandler"},{"id":"110763","_route":"notes.notes_api.update"}]},{"file":"\/data\/WWW\
/nc.site.name\/htdocs\/lib\/base.php","line":997,"function":"match","class":"OC\\Route\\Router","type":"->","args":["\/apps\/notes\/api\/v0.2\/notes\/110763"]},{"file":"\/da
ta\/WWW\/nc.site.name\/htdocs\/index.php","line":42,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/
Files\/View.php","Line":1945,"Previous":{"Exception":"OCP\\Lock\\LockedException","Message":"\"files\/f8723289aff75e52d945bc90cffdabc6\" is locked, existing lock on file: ex
clusive","Code":0,"Trace":[{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Files\/Storage\/Common.php","line":743,"function":"acquireLock","class":"OC\\Lock\\Memca
cheLockingProvider","type":"->","args":["files\/f8723289aff75e52d945bc90cffdabc6",1]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Files\/Storage\/Wrapper\/Wrap
per.php","line":593,"function":"acquireLock","class":"OC\\Files\\Storage\\Common","type":"->","args":["files\/Notes\/Boeken 1.txt",1,{"__class__":"OC\\Lock\\MemcacheLockingP
rovider"}]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Files\/Storage\/Wrapper\/Wrapper.php","line":593,"function":"acquireLock","class":"OC\\Files\\Storage\\
Wrapper\\Wrapper","type":"->","args":["files\/Notes\/Boeken 1.txt",1,{"__class__":"OC\\Lock\\MemcacheLockingProvider"}]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/pri
vate\/Files\/Storage\/Wrapper\/Wrapper.php","line":593,"function":"acquireLock","class":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->","args":["files\/Notes\/Boeken 1.tx
t",1,{"__class__":"OC\\Lock\\MemcacheLockingProvider"}]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Files\/View.php","line":1940,"function":"acquireLock","cla
ss":"OC\\Files\\Storage\\Wrapper\\Wrapper","type":"->","args":["files\/Notes\/Boeken 1.txt",1,{"__class__":"OC\\Lock\\MemcacheLockingProvider"}]},{"file":"\/data\/WWW\/nc.si
te.name\/htdocs\/lib\/private\/Files\/View.php","line":2050,"function":"lockPath","class":"OC\\Files\\View","type":"->","args":["\/username\/files\/Notes\/Boeken 1.txt",1,"*
** sensitive parameter replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Files\/View.php","line":1140,"function":"lockFile","class":"OC\\Files\\View"
,"type":"->","args":["\/username\/files\/Notes\/Boeken 1.txt",1]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Files\/View.php","line":994,"function":"basicOper
ation","class":"OC\\Files\\View","type":"->","args":["fopen","\/username\/files\/Notes\/Boeken 1.txt",["read"],"r"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private
\/Files\/Node\/File.php","line":108,"function":"fopen","class":"OC\\Files\\View","type":"->","args":["\/username\/files\/Notes\/Boeken 1.txt","r"]},{"file":"\/data\/WWW\/nc.
site.name\/htdocs\/apps\/ransomware_detection\/lib\/Analyzer\/EntropyAnalyzer.php","line":164,"function":"fopen","class":"OC\\Files\\Node\\File","type":"->","args":["r"]},{"
file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/ransomware_detection\/lib\/Analyzer\/EntropyAnalyzer.php","line":105,"function":"calculateEntropyOfFile","class":"OCA\\Ransom
wareDetection\\Analyzer\\EntropyAnalyzer","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"}]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/ransomware_detection\
/lib\/Monitor.php","line":450,"function":"analyze","class":"OCA\\RansomwareDetection\\Analyzer\\EntropyAnalyzer","type":"->","args":[{"__class__":"OC\\Files\\Node\\File"}]},
{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/ransomware_detection\/lib\/Monitor.php","line":207,"function":"addFileOperation","class":"OCA\\RansomwareDetection\\Monitor
","type":"->","args":[["files\/Notes\/Boeken 1.txt"],{"__class__":"OC\\Files\\Node\\File"},3]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/ransomware_detection\/lib\/S
torageWrapper.php","line":257,"function":"analyze","class":"OCA\\RansomwareDetection\\Monitor","type":"->","args":[{"mountPoint":"\/username\/","cache":null,"scanner":null,"
watcher":null,"propagator":null,"updater":null,"__class__":"OCA\\RansomwareDetection\\StorageWrapper"},["files\/Notes\/Boeken 1.txt"],3]},{"file":"\/data\/WWW\/nc.site.name\
/htdocs\/apps\/ransomware_detection\/lib\/StorageWrapper.php","line":98,"function":"analyze","class":"OCA\\RansomwareDetection\\StorageWrapper","type":"->","args":[{"mountPo
int":"\/username\/","cache":null,"scanner":null,"watcher":null,"propagator":null,"updater":null,"__class__":"OCA\\RansomwareDetection\\StorageWrapper"},["files\/Notes\/Boeke
n 1.txt"],3]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/ransomware_protection\/lib\/StorageWrapper.php","line":252,"function":"file_put_contents","class":"OCA\\Ranso
mwareDetection\\StorageWrapper","type":"->","args":["files\/Notes\/Boeken 1.txt","*** sensitive parameter replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/pr
ivate\/Files\/View.php","line":1158,"function":"file_put_contents","class":"OCA\\RansomwareProtection\\StorageWrapper","type":"->","args":["files\/Notes\/Boeken 1.txt","***
sensitive parameter replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Files\/View.php","line":694,"function":"basicOperation","class":"OC\\Files\\Vie
w","type":"->","args":["file_put_contents","\/username\/files\/Notes\/Boeken 1.txt",["update","write"],"*** sensitive parameter replaced ***"]},{"file":"\/data\/WWW\/nc.site
.name\/htdocs\/lib\/private\/Files\/Node\/File.php","line":66,"function":"file_put_contents","class":"OC\\Files\\View","type":"->","args":["\/username\/files\/Notes\/Boeken
1.txt","*** sensitive parameter replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/notes\/lib\/Service\/NotesService.php","line":176,"function":"putContent","
class":"OC\\Files\\Node\\File","type":"->","args":["*** sensitive parameter replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/notes\/lib\/Controller\/NotesAp
iController.php","line":177,"function":"update","class":"OCA\\Notes\\Service\\NotesService","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/data\/WW
W\/nc.site.name\/htdocs\/apps\/notes\/lib\/Controller\/NotesApiController.php","line":158,"function":"updateData","class":"OCA\\Notes\\Controller\\NotesApiController","type"
:"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/apps\/notes\/lib\/Controller\/Errors.php","line":22,"function":"OCA\\Note
s\\Controller\\{closure}","class":"OCA\\Notes\\Controller\\NotesApiController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/data\/WWW\/nc.site.na
me\/htdocs\/apps\/notes\/lib\/Controller\/NotesApiController.php","line":159,"function":"respond","class":"OCA\\Notes\\Controller\\NotesApiController","type":"->","args":[{"
__class__":"Closure"}]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/AppFramework\/Http\/Dispatcher.php","line":170,"function":"update","class":"OCA\\Notes\\Con
troller\\NotesApiController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/AppFramework\/Http\/Disp
atcher.php","line":99,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Notes\\Controller\\NotesApiControlle
r"},"update"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/AppFramework\/App.php","line":126,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher"
,"type":"->","args":[{"__class__":"OCA\\Notes\\Controller\\NotesApiController"},"update"]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/AppFramework\/Routing\/R
outeActionHandler.php","line":47,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Notes\\Controller\\NotesApiController","update",{"__class__":"OC
\\AppFramework\\DependencyInjection\\DIContainer"},{"id":"110763","_route":"notes.notes_api.update"}]},{"function":"__invoke","class":"OC\\AppFramework\\Routing\\RouteAction
Handler","type":"->","args":[{"id":"110763","_route":"notes.notes_api.update"}]},{"file":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Route\/Router.php","line":297,"fun
ction":"call_user_func","args":[{"__class__":"OC\\AppFramework\\Routing\\RouteActionHandler"},{"id":"110763","_route":"notes.notes_api.update"}]},{"file":"\/data\/WWW\/nc.si
te.name\/htdocs\/lib\/base.php","line":997,"function":"match","class":"OC\\Route\\Router","type":"->","args":["\/apps\/notes\/api\/v0.2\/notes\/110763"]},{"file":"\/data\/WW
W\/nc.site.name\/htdocs\/index.php","line":42,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"\/data\/WWW\/nc.site.name\/htdocs\/lib\/private\/Lock\/
MemcacheLockingProvider.php","Line":75},"CustomMessage":"--"},"userAgent":"Mozilla\/5.0 (Android) Nextcloud-android\/3.9.2","version":"17.0.2.1"}
Level
App Message Time
Warning news https://nextcloud.com/blog/feed// read error : cURL error 7: Failed to connect to nextcloud.com port 443: Connection timed out (see http://curl.haxx.se/libcurl/c/libcurl-errors.html) 15 minuten geleden
Error index OCP\Lock\LockedException: "Notes/testje.txt" is locked 18 minuten geleden
Error index OCP\Lock\LockedException: "Notes/Boeken 1.txt" is locked 18 minuten geleden
The above message (there are more of them) are only from a problem in the Notes app. (it appearantly locks a file and then cannot upload it… (different issue from phone).
No other messages visible:
I’ll try the get a better log for nextcloud logging. Not sure how to obtains that for /settings specifically though.
