Hello all!
Nextcloud version (eg, 12.0.2): 16.0.5
Operating system and version (eg, Ubuntu 17.04): CentOS 6.10
Apache or nginx version (eg, Apache 2.4.25): 2.2.15
PHP version (eg, 7.1): 7.3.10
Running the security scan inside Nextcloud Settings/Overview shows it’s running 15.0.7.0 even though 16.0.5 is installed according to the info in /var/www/html/nextcloud/version.php.
- Login to NC web-gui.
- Go to settings/overview.
- Click the link " Check the security of your Nextcloud over our security scan ."
The output at scan.nextcloud.com:
Running Nextcloud 15.0.7.0
X NOT on latest patch level
V Major version still supported
Scanned at 2019-04-15 08:27:43
'passwordsalt' => 'XXX',
'secret' => 'XXX',
0 => 'XXX',
1 => 'XXX',
2 => 'XXX',
'datadirectory' => '/var/www/html/nextcloud/data',
'overwrite.cli.url' => 'http://localhost',
'version' => '16.0.5.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'oc_admin',
'dbpassword' => 'XXX',
'logtimezone' => 'UTC',
'instanceid' => 'XXX',
'mail_from_address' => 'XXX',
'mail_smtpmode' => 'sendmail',
'mail_domain' => 'XXX',
'theme' => '',
'loglevel' => 2,
'memcache.locking' => '\\OC\\Memcache\\APCu',
'trashbin_retention_obligation' => '15, 20',
'enable_previews' => true,
'mail_smtphost' => 'XXX',
'mail_smtpport' => 'XXX',
'auth.bruteforce.protection.enabled' => false,
'mail_smtpdebug' => true,
'mail_smtpsecure' => 'ssl',
'mail_smtpauth' => 1,
'twofactor_enforced' => 'false',
'app_install_overwrite' =>
0 => 'activitylog',
1 => 'impersonate',
