- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
Nextcloud AIO v12.5.0
Debian 13
replace me
Caddyv2.10.2
- PHP version (e.g, 8.3):
replace me
replace me
After install
AIO
No
Cannot submit domain. Yields the following popup error: “Domain does not point to this server or the reverse proxy is not configured correctly. See the mastercontainer logs for more details. (‘sudo docker logs -f nextcloud-aio-mastercontainer’)”
Create DNS records on the domain registrar for the mydomain.ca and cloud.mydomain.ca, both pointing to a fresh VPS.
VPS is installed with iptables-nft and the following firewall rules manually set up (ignoring docker rules):
-P INPUT DROP -P FORWARD DROP -P OUTPUT ACCEPT -A INPUT -p tcp -m tcp --dport 80 -j ACCEPT -A INPUT -m conntrack --ctstate RELATED,ESTABLISHED -j ACCEPT -A INPUT -p tcp -m tcp --dport 22 -j ACCEPT -A INPUT -p tcp -m tcp --dport 443 -j ACCEPT -A INPUT -p tcp -m tcp --dport 3478 -j ACCEPT -A INPUT -p udp -m udp --dport 3478 -j ACCEPT -A INPUT -p tcp -m tcp --dport 8443 -j ACCEPT -A INPUT -p tcp -m tcp --dport 8080 -j ACCEPT -
Caddy as the fronting reverse proxy and Nextcloud AIO are set up with the following compose.yaml which is based on the sample at https://github.com/nextcloud/all-in-one/discussions/575 .
services: caddy: image: caddy:alpine restart: unless-stopped container_name: caddy volumes: - ./Caddyfile:/etc/caddy/Caddyfile - ./config:/config - ./data:/data - ./sites:/srv network_mode: "host" nextcloud: image: nextcloud/all-in-one:latest restart: unless-stopped container_name: nextcloud-aio-mastercontainer ports: - "8080:8080" environment: - APACHE_PORT=11000 - APACHE_IP_BINDING=127.0.0.1 volumes: - nextcloud_aio_mastercontainer:/mnt/docker-aio-config - /var/run/docker.sock:/var/run/docker.sock:ro depends_on: - caddy volumes: nextcloud_aio_mastercontainer: name: nextcloud_aio_mastercontainer -
The following Caddyfile was used. Note that Caddy serves files for mydomain.ca with an autogenerated cert and the cloud.mydomain.ca subdomain is forwarded to the AIO.
https://cloud.mydomain.ca:443 { header Strict-Transport-Security max-age=31536000; # Adjust to match APACHE_PORT and APACHE_IP_BINDING. See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md#adapting-the-sample-web-server-configurations-below reverse_proxy localhost:11000 } mydomain.ca { root * /srv/mydomain.ca file_server tls a_user@some_mail.com } -
Start the system
docker compose up [+] up 4/4 ✔ Network server_default Created 0.0s ✔ Volume nextcloud_aio_mastercontainer Created 0.0s ✔ Container caddy Created 0.1s ✔ Container nextcloud-aio-mastercontainer Created 0.1s Attaching to caddy, nextcloud-aio-mastercontainer caddy | {“level”:“info”,“ts”:1769786001.8112128,“msg”:“maxprocs: Leaving GOMAXPROCS=2: CPU quota undefined”} caddy | {“level”:“info”,“ts”:1769786001.8115678,“msg”:“GOMEMLIMIT is updated”,“package”:“github.com/KimMachineGun/automemlimit/memlimit",“GOMEMLIMIT”:7501064601,"previous”:9223372036854775807} caddy | {“level”:“info”,“ts”:1769786001.8120391,“msg”:“using config from file”,“file”:“/etc/caddy/Caddyfile”} caddy | {“level”:“info”,“ts”:1769786001.8141012,“msg”:“adapted config to JSON”,“adapter”:“caddyfile”} caddy | {“level”:“info”,“ts”:1769786001.8154073,“logger”:“admin”,“msg”:“admin endpoint started”,“address”:“localhost:2019”,“enforce_origin”:false,“origins”:[“//[::1]:2019”,“//127.0.0.1:2019”,“//localhost:2019”]} caddy | {“level”:“info”,“ts”:1769786001.8160043,“logger”:“tls.cache.maintenance”,“msg”:“started background certificate maintenance”,“cache”:“0xc00062ac00”} caddy | {“level”:“info”,“ts”:1769786001.8165526,“logger”:“http.auto_https”,“msg”:“server is listening only on the HTTPS port but has no TLS connection policies; adding one to enable TLS”,“server_name”:“srv0”,“https_port”:443} caddy | {“level”:“info”,“ts”:1769786001.8167696,“logger”:“http.auto_https”,“msg”:“enabling automatic HTTP->HTTPS redirects”,“server_name”:“srv0”} caddy | {“level”:“info”,“ts”:1769786001.818084,“logger”:“http”,“msg”:“enabling HTTP/3 listener”,“addr”:“:443”} caddy | {“level”:“info”,“ts”:1769786001.8184545,“msg”:“failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 7168 kiB, got: 416 kiB). See for details.”} caddy | {“level”:“info”,“ts”:1769786001.8192825,“logger”:“http.log”,“msg”:“server running”,“name”:“srv0”,“protocols”:[“h1”,“h2”,“h3”]} caddy | {“level”:“warn”,“ts”:1769786001.8196764,“logger”:“http”,“msg”:“HTTP/2 skipped because it requires TLS”,“network”:“tcp”,“addr”:“:80”} caddy | {“level”:“warn”,“ts”:1769786001.819935,“logger”:“http”,“msg”:“HTTP/3 skipped because it requires TLS”,“network”:“tcp”,“addr”:“:80”} caddy | {“level”:“info”,“ts”:1769786001.8200164,“logger”:“http.log”,“msg”:“server running”,“name”:“remaining_auto_https_redirects”,“protocols”:[“h1”,“h2”,“h3”]} caddy | {“level”:“info”,“ts”:1769786001.8200912,“logger”:“http”,“msg”:“enabling automatic TLS certificate management”,“domains”:[“cloud.mydomain.ca”,“mydomain.ca”]} caddy | {“level”:“info”,“ts”:1769786001.8218472,“msg”:“autosaved config (load with --resume flag)”,“file”:“/config/caddy/autosave.json”} caddy | {“level”:“info”,“ts”:1769786001.8222244,“msg”:“serving initial configuration”} caddy | {“level”:“info”,“ts”:1769786001.8246408,“logger”:“tls”,“msg”:“storage cleaning happened too recently; skipping for now”,“storage”:“FileStorage:/data/caddy”,“instance”:“b631342d-0b14-4259-8aa3-95bcbdca04bd”,“try_again”:1769872401.8246381,“try_again_in”:86399.999999399} caddy | {“level”:“info”,“ts”:1769786001.8247738,“logger”:“tls”,“msg”:“finished cleaning storage units”} nextcloud-aio-mastercontainer | Trying to fix docker.sock permissions internally… nextcloud-aio-mastercontainer | Creating docker group internally with id 989 nextcloud-aio-mastercontainer | …+…+..+…+…+++++++++++++++++++++++++++++++++++++++++++++.+…+…+…+…+…+…+…+…+.+…+..+…+..+…+..+…+…+…+..+…+…+…+…+..+…+…+..+.+..+…+.+…+…+.+..+.+..+…+…+.+…+.+…+…+…+…+..+.+…+…+..+…+…+…+…+…+…+.+…+…+…+..+++++++++++++++++++++++++++++++++++++++++++++…+…+.+…+…+…+…+…+…+…+.+..+.+++++ nextcloud-aio-mastercontainer | …+.+…+…+…+…+…+.+..+++++++++++++++++++++++++++++++++++++++++++++..+++++++++++++++++++++++++++++++++++++++++++++…+…+…+…+.+…+…+..+.+..+…+…+…+…+..+…+…+…+…+…+…+.+…+…+…+…+..+…+…+..+…+.+…+…+…+.+…+…+…+…+…+…+…+…+…+…+…+…+..+…+…+…+..+…+…+…+…+…+…+…+…+…+..+…+…+..+…+…+…+…+…+…+.+..+…+.+..+.+…+.+…+…+…+..+…+.+…+…+…+…+…+…+…+.+…+…+…+…+.+…+..+…+…+..+…+…+…+.+…+…+…+…+…+…+…+…+.+…+.+…+…+…+…+…+…+…+…+..+…+…+…+.+…+…+…+…+…+…+…+…+…+…+…+.+…+++++ nextcloud-aio-mastercontainer | ----- nextcloud-aio-mastercontainer | Initial startup of Nextcloud All-in-One complete! nextcloud-aio-mastercontainer | You should be able to open the Nextcloud AIO Interface now on port 8080 of this server! nextcloud-aio-mastercontainer | E.g. https://internal.ip.of.this.server:8080 nextcloud-aio-mastercontainer | ⚠️ Important: do always use an ip-address if you access this port and not a domain as HSTS might block access to it later! nextcloud-aio-mastercontainer | [30-Jan-2026 15:13:23] NOTICE: fpm is running, pid 138 nextcloud-aio-mastercontainer | [30-Jan-2026 15:13:23] NOTICE: ready to handle connections nextcloud-aio-mastercontainer | [Fri Jan 30 15:13:23.987563 2026] [mpm_event:notice] [pid 133:tid 133] AH00489: Apache/2.4.66 (Unix) OpenSSL/3.5.4 configured – resuming normal operations nextcloud-aio-mastercontainer | [Fri Jan 30 15:13:23.988256 2026] [core:notice] [pid 133:tid 133] AH00094: Command line: ‘httpd -D FOREGROUND’ nextcloud-aio-mastercontainer | {“level”:“info”,“ts”:1769786004.0032039,“msg”:“maxprocs: Leaving GOMAXPROCS=2: CPU quota undefined”} nextcloud-aio-mastercontainer | {“level”:“info”,“ts”:1769786004.0033894,“msg”:“GOMEMLIMIT is updated”,“package”:“github.com/KimMachineGun/automemlimit/memlimit",“GOMEMLIMIT”:7501064601,"previous”:9223372036854775807} nextcloud-aio-mastercontainer | {“level”:“info”,“ts”:1769786004.0034254,“msg”:“using config from file”,“file”:“/Caddyfile”} nextcloud-aio-mastercontainer | {“level”:“info”,“ts”:1769786004.0058382,“msg”:“adapted config to JSON”,“adapter”:“caddyfile”} nextcloud-aio-mastercontainer | {“level”:“info”,“ts”:1769786004.008718,“msg”:“serving initial configuration”} -
In Firefox, go to
https://cloud.mydomain.ca:8080to get the passphrase to login to NC AIO. -
Login to get the page that has “Submit domain” on it.
enter cloud.mydomain.ca and click Submit domain
The following is emitted in the logs showing the connection was refused:
caddy | {"level":"error","ts":1769786143.4509768,"logger":"http.log.error","msg":"dial tcp [::1]:11000: connect: connection refused","request":{"remote_ip":"172.19.0.2","remote_port":"35958","client_ip":"172.19.0.2","proto":"HTTP/2.0","method":"GET","host":"cloud.mydomain.ca","uri":"/","headers":{"Accept":["*/*"]},"tls":{"resumed":false,"version":772,"cipher_suite":4865,"proto":"h2","server_name":"cloud.mydomain.ca"}},"duration":3.000433088,"status":502,"err_id":"cec0i0bu0","err_trace":"reverseproxy.statusError (reverseproxy.go:1390)"} nextcloud-aio-mastercontainer | NOTICE: PHP message: The response of the connection attempt to "https://cloud.mydomain.ca:443" was: nextcloud-aio-mastercontainer | NOTICE: PHP message: Expected was: 96e1225a2898a4007d1e4af7e486341b0b93a4c5791627e9 nextcloud-aio-mastercontainer | NOTICE: PHP message: The error message was: nextcloud-aio-mastercontainer | NOTICE: PHP message: Please follow https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md#how-to-debug in order to debug things! -
The nextcloud-aio-domaincheck container is supposed to be exposing localhost:11000, but hitting that port with nc hangs.
$ docker ps -a CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES e7639b878161 ghcr.io/nextcloud-releases/aio-domaincheck:latest "/start.sh" 41 minutes ago Up 41 minutes (healthy) 127.0.0.1:11000->11000/tcp nextcloud-aio-domaincheck dd81c83d8416 nextcloud/all-in-one:latest "/start.sh" 43 minutes ago Up 43 minutes (healthy) 80/tcp, 8443/tcp, 9000/tcp, 0.0.0.0:8080->8080/tcp, [::]:8080->8080/tcp nextcloud-aio-mastercontainer 026879b736ed caddy:alpine "caddy run --config …" 43 minutes ago Up 43 minutes caddy $ nc -z 127.0.0.1 11000; echo $? <note: nc does not return>
see above
POST /api/configuration HTTP/1.1
Host: cloud.mydomain.ca:8080
User-Agent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0
Accept: */*
Accept-Language: en-US,en;q=0.9
Accept-Encoding: gzip, deflate, br, zstd
Content-type: application/x-www-form-urlencoded
Content-Length: 163
Origin: https://cloud.mydomain.ca:8080
DNT: 1
Sec-GPC: 1
Connection: keep-alive
Referer: https://cloud.mydomain.ca:8080/containers
Cookie: PHPSESSID=c982a956c3359171fd781c595beee2be
Sec-Fetch-Dest: empty
Sec-Fetch-Mode: cors
Sec-Fetch-Site: same-origin
Priority: u=0
HTTP/1.1 422 Unprocessable Entity
Date: Fri, 30 Jan 2026 16:08:32 GMT
Server: Apache/2.4.66 (Unix)
X-Powered-By: PHP/8.4.16
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
Content-Type: text/html; charset=UTF-8
Keep-Alive: timeout=5, max=100
Connection: Keep-Alive
Transfer-Encoding: chunked
PASTE HERE
/bin/sh: occ: not found
