thanks for your patience guys⦠yes, the key here is to be able to reproduce, or understand at what point things are going south
I just started from scratch several times. Always the same timeout-errorā¦
What I did:
- tried different Berryboot-versions (
berryboot-20170527-pi0-pi1-pi2-pi3
andberryboot-20170527-pi2-pi3
) - tried different harddrives (WD Pi Drive 375GB and a 600GB 2.5" drive)
- checked md5sum of NextCloudPi-Berryboot-Image (
NextCloudPi_12-04-17_berryboot.img
Berryboot works fine in all setups, no errors during installation, also installing other operation systems (Kodi, Debian, Nextcloud 11) and running them works without problems.
So what else could it be?
I know, it doesnāt help, but I can confirm: Berryboot is working fine - and the harddrive as well. Other images (including NC11) are being installed correctly and work from the usb drive. Only NCP still refuses working.
really weird⦠can somebody confim that it does work for them? so we can find out the differences
That would be interesting. And if someone with a running berryboot-ncp could post the output of cat /etc/fstab
of the berryboot console (opened in berryboot menu - more options - username: root
, no password) we could see, if its any different to my āfstabā contentā¦
@OliverV, were you referring to /dev/mcblk0p1
or to /dev/mmcblk0p1 (with double m) ?
Because only the later one is showing up using ls /dev
in berryboot consoleā¦
Tried to edit typo, couldnāt, should be /dev/mmcblk0p1 with 2mās
I does work for me, as mentioned
Did so yesterday and it works fine.
Could you post the output of cat /etc/fstab of the berryboot console to see, if its any different to my āfstabā content?
The error seems to be related to fstab, as far as I understand google-search-resultsā¦
:~ $ cat /etc/fstab
proc /proc proc defaults 0 0
PARTUUID=09efbd88-01 /boot vfat defaults 0 2
PARTUUID=09efbd88-02 / ext4 defaults,noatime 0 1
#a swapfile is not a swap partition, no line here
#use dphys-swapfile swap[on|off] for that
UUID=d549f07b-1751-40c1-bafb-3ca162605aca /media/user/usb1t ext4 rw,users 0 0
df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 29G 2.4G 25G 9% /
devtmpfs 484M 0 484M 0% /dev
tmpfs 489M 0 489M 0% /dev/shm
tmpfs 489M 19M 470M 4% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 489M 0 489M 0% /sys/fs/cgroup
/dev/mmcblk0p1 42M 21M 21M 51% /boot
/dev/sda1 917G 15G 856G 2% /media/user/usb1t
tmpfs 98M 0 98M 0% /run/user/1000
NextCloudPi v0.41.13 is up to date
Can you start the NC11 to see what fstab and df show?
Unfortunately I donāt know the default login/password to get access to NC11 berryboot version (and couldnt find it on the internet either). If you can tell me what it is I can post the output
I think itās the default:
user=pi
passwd=raspberry
Didnāt workā¦
Can you be litlle more specific, its not possible to investigate : Didnāt work!
A screenshot possibly?
The second screenshot in #8 show the login screen. I tried different āstandardā password combinations and searched the webā¦
Edit: Sorry for the confusion, username pi
and password raspberry
work (only difficult to type as the german keyboard layout changes y
and z
ā¦)!
Okay, I just found the chroot_image
command for the berryboot console. It looks quit useful. I mounted different operating systems and used cat /etc/fstab
to be able to compare the diffences.
Here are the results:
NextcloudPi-Image
Nextcloud 11 (featured)
and DiepPi (Debian Jessie OS)
Is this any help at all?
I got it to work!!!
I changed the fstab
using vi
according to the fstab
of NC11. And that worked perfectly! No more timeout error! So I guess this is the place to edit
Here are the screenshots including my fstab file
Hopefully this helps to prevent this error in the future!
Keep me up to date!
good job!
Glad you got it to work, but still puzzled tho, as how this happened.
