nslookup www.nextcloud.com in bash at 19:57:44
Server: 100.100.100.100
Address: 100.100.100.100#53
Non-authoritative answer:
Address: 95.217.53.155
Address: 2a01:4f9:2b:29dc::155
nslookup download.nextcloud.com
Address: 95.217.64.181
Address: 2a01:4f9:2a:3119::181
curl -v -L https://www.nextcloud.com
* Trying 95.217.53.155:443...
* Trying 2a01:4f9:2b:29dc::155:443...
* Immediate connect fail for 2a01:4f9:2b:29dc::155: Network is unreachable
curl -v -L https://download.nextcloud.com/server/installer/setup-nextcloud.php in bash at 19:58:00
* Trying 95.217.64.181:443...
* Trying 2a01:4f9:2a:3119::181:443...
* Immediate connect fail for 2a01:4f9:2a:3119::181: Network is unreachable
ping 95.217.53.155 in bash at 20:01:58
PING 95.217.53.155 (95.217.53.155) 56(84) bytes of data.
^C
--- 95.217.53.155 ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 4089ms
Force ipv4 or use wget is same.
Would this be cdn issue?
Accesing from my laptop doesn’t have any issue and server ip address resolv is same ip.
Maybe you can better download https://download.nextcloud.com/server/releases/latest.zip to your laptop, upload the zip file to your server, unzip the archive and use parts of an installation guide e.g. this (Debian) or this.
For your problem. Can you check traceroute and your firewall settings? Sometimes also there are problems with the server. Test it again.
Thanks, it seems it is firewall issue (for strange reason, the nextcloud ips are in the blocklist)
