I have a folder that I can not delete because it is locked. How do I clear a lock on a file or folder?
If you direct me to run a command such as “sudo -u www-data php occ files:scan --all” which was suggested in one post and worked for some but not all people, could you please let me know how to find the correct directory to run this command? I can’t remember how I managed to find the real root directory for nextcloud the last time I looked for it ages ago.
