Hi, I’ve just upgraded NC v24 to v25 and everything seemed to go well. After upgrade has finished home page comes up blank. Admin page is functional and shows most services up. However, HBP service shows as down.
I’d appreciate some guidance. Below are my logs:
<–! Paste this in GitHub report →
NextcloudPi diagnostics
NextcloudPi version v1.51.0
NextcloudPi image NextCloudPi_07-25-22
OS Debian GNU/Linux 11. 5.15.84-v8+ (aarch64)
automount yes
USB devices sda sdb
datadir /var/www/nextcloud/data
data in SD yes
data filesystem ext2/ext3
data disk usage 317G/917G
rootfs usage 317G/917G
swapfile /var/swap
dbdir /var/lib/mysql
Nextcloud check ok
Nextcloud version 25.0.4.1
HTTPD service up
PHP service up
MariaDB service up
Redis service up
HPB service down
Postfix service up
Internet check ok
Public IPv4 ***REMOVED SENSITIVE VALUE***
Public IPv6 ***REMOVED SENSITIVE VALUE***
Port 80 open
Port 443 open
IP ***REMOVED SENSITIVE VALUE***
Gateway ***REMOVED SENSITIVE VALUE***
Interface eth0
Certificates ***REMOVED SENSITIVE VALUE***
NAT loopback no
Uptime 7min
Nextcloud configuration
Nextcloud or one of the apps require upgrade - only a limited number of commands are available
You may use your browser or the occ upgrade command to do the upgrade
"trusted_domains": {
"0": "localhost",
"11": "135.134.39.232",
"1": "192.168.1.113",
"5": "nextcloudpi.local",
"7": "nextcloudpi",
"8": "nextcloudpi.lan",
"3": "nextcloudpi",
"4": "ncp.120v.ac",
"12": "ncp.120v.ac",
"22": "nextcloudpi",
"": "ncp.120v.ac",
"14": "nextcloudpi"
"dbtype": "mysql",
"version": "24.0.10.1",
"overwrite.cli.url": "https:\/\/nextcloudpi\/",
"dbport": "",
"mysql.utf8mb4": true,
"redis": {
"port": 0,
"timeout": 0,
"tempdirectory": "\/var\/www\/nextcloud\/data\/tmp",
"mail_smtpmode": "smtp",
"mail_smtpauthtype": "LOGIN",
"jpeg_quality": "60",
"overwriteprotocol": "https",
"loglevel": "2",
"log_type": "file",
"mail_sendmailmode": "smtp",
"mail_smtpsecure": "tls",
"mail_smtpauth": 1,
"mail_smtpport": "587",
"preview_max_x": "2048",
"preview_max_y": "2048",
"theme": "",
"twofactor_enforced": "true",
"admin"
"data-fingerprint": "f9fc5aceb264fe72c4245e92c0d7baad",
"app_install_overwrite": [
"bookmarks_fulltextsearch"
"default_phone_region": "US",
"logfile": "\/var\/www\/nextcloud\/data\/nextcloud.log",
"updater.secret": "***REMOVED SENSITIVE VALUE***"
HTTPd logs
[Thu Mar 02 21:47:31.741047 2023] [authz_host:error] [pid 607:tid 548277399936] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/settings-white.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.113:4443/css/ncp.css
[Thu Mar 02 21:47:31.741530 2023] [authz_host:error] [pid 607:tid 548252205440] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/search.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.113:4443/css/ncp.css
[Thu Mar 02 21:47:31.741798 2023] [authz_host:error] [pid 607:tid 548260606336] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/dashboard.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.113:4443/css/ncp.css
[Thu Mar 02 21:47:31.741938 2023] [authz_host:error] [pid 607:tid 548285792640] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/ncp-logo.svg failed, reason: unable to get the remote host name
[Thu Mar 02 21:47:31.746990 2023] [authz_host:error] [pid 607:tid 548260606336] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Thu Mar 02 21:47:31.764056 2023] [authz_host:error] [pid 607:tid 548269007232] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/defaults.svg failed, reason: unable to get the remote host name
[Thu Mar 02 21:47:31.772234 2023] [authz_host:error] [pid 607:tid 548294185344] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/poweroff.svg failed, reason: unable to get the remote host name
[Thu Mar 02 21:47:31.777276 2023] [authz_host:error] [pid 607:tid 548302578048] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/reboot.svg failed, reason: unable to get the remote host name
[Thu Mar 02 21:47:31.784504 2023] [authz_host:error] [pid 607:tid 548319363456] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/logs.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.113:4443/css/ncp.css
[Thu Mar 02 21:47:31.805240 2023] [authz_host:error] [pid 607:tid 548277399936] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/wizard.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.113:4443/css/ncp.css
[Thu Mar 02 21:47:31.806705 2023] [authz_host:error] [pid 607:tid 548310970752] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/files.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.113:4443/css/ncp.css
[Thu Mar 02 21:47:31.806705 2023] [authz_host:error] [pid 607:tid 548327756160] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/info-white.svg failed, reason: unable to get the remote host name, referer: https://192.168.1.113:4443/css/ncp.css
[Thu Mar 02 21:47:31.813815 2023] [authz_host:error] [pid 607:tid 548285792640] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /ncp-output.php failed, reason: unable to get the remote host name
[Thu Mar 02 21:47:36.843174 2023] [authz_host:error] [pid 607:tid 548260606336] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Thu Mar 02 21:47:36.867496 2023] [authz_host:error] [pid 607:tid 548260606336] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/download.svg failed, reason: unable to get the remote host name
[Thu Mar 02 21:47:36.867496 2023] [authz_host:error] [pid 607:tid 548310970752] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /img/delete.svg failed, reason: unable to get the remote host name
[Thu Mar 02 21:47:36.868923 2023] [authz_host:error] [pid 607:tid 548310970752] [client 192.168.1.114:53752] AH01753: access check of 'localhost' to /ncp-launcher.php failed, reason: unable to get the remote host name
[Thu Mar 02 21:51:01.302112 2023] [proxy_fcgi:error] [pid 607:tid 548285792640] [client 192.168.1.114:53752] AH01067: Failed to read FastCGI header
[Thu Mar 02 21:51:01.302309 2023] [proxy_fcgi:error] [pid 607:tid 548285792640] (104)Connection reset by peer: [client 192.168.1.114:53752] AH01075: Error dispatching request to :4443:
[Thu Mar 02 21:51:06.338515 2023] [authz_host:error] [pid 607:tid 548285792640] [client 192.168.1.114:54043] AH01753: access check of 'localhost' to /ncp-output.php failed, reason: unable to get the remote host name
Database logs
tail: cannot open '/var/log/mysql/*.log' for reading: No such file or directory
Nextcloud logs
{"reqId":"ZAEUp7GN1HVsCSbZMGqf9wAAAwI","level":3,"time":"2023-03-02T21:27:03+00:00","remoteAddr":"192.168.1.114","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEU0vn5EXRqUxdkPY31-AAAAFA","level":3,"time":"2023-03-02T21:27:46+00:00","remoteAddr":"192.168.1.10","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEU0_n5EXRqUxdkPY31-gAAAFc","level":3,"time":"2023-03-02T21:27:48+00:00","remoteAddr":"192.168.1.10","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEVNfn5EXRqUxdkPY31-wAAAEw","level":3,"time":"2023-03-02T21:29:26+00:00","remoteAddr":"192.168.1.10","user":"--","app":"PHP","method":"OPTIONS","url":"/remote.php/dav/principals/users/ozlem/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"iOS/15.3.1 (19D52) remindd/1.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEVc_n5EXRqUxdkPY31_wAAAEg","level":3,"time":"2023-03-02T21:30:27+00:00","remoteAddr":"192.168.1.10","user":"--","app":"PHP","method":"OPTIONS","url":"/remote.php/dav/principals/users/ozlem/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"iOS/15.3.1 (19D52) remindd/1.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEVeLGN1HVsCSbZMGqgAQAAABA","level":3,"time":"2023-03-02T21:30:32+00:00","remoteAddr":"192.168.1.10","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEVkbGN1HVsCSbZMGqgAgAAGAI","level":3,"time":"2023-03-02T21:30:57+00:00","remoteAddr":"192.168.1.114","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEV8vn5EXRqUxdkPY32BwAAAEk","level":3,"time":"2023-03-02T21:32:34+00:00","remoteAddr":"192.168.1.10","user":"--","app":"PHP","method":"OPTIONS","url":"/remote.php/dav/principals/users/ozlem/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"iOS/15.3.1 (19D52) remindd/1.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEWA_n5EXRqUxdkPY32CQAAVQE","level":3,"time":"2023-03-02T21:32:51+00:00","remoteAddr":"192.168.1.114","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEWo_n5EXRqUxdkPY32KAAAUwI","level":3,"time":"2023-03-02T21:35:31+00:00","remoteAddr":"192.168.1.114","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEWp_n5EXRqUxdkPY32KQAASQI","level":3,"time":"2023-03-02T21:35:35+00:00","remoteAddr":"192.168.1.114","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEW_vn5EXRqUxdkPY32LAAAAEI","level":3,"time":"2023-03-02T21:37:02+00:00","remoteAddr":"192.168.1.10","user":"--","app":"PHP","method":"OPTIONS","url":"/remote.php/dav/principals/users/ozlem/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"iOS/15.3.1 (19D52) remindd/1.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEX8LGN1HVsCSbZMGqgBgAAAgI","level":3,"time":"2023-03-02T21:41:04+00:00","remoteAddr":"192.168.1.114","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEX8fn5EXRqUxdkPY32NgAAAEQ","level":3,"time":"2023-03-02T21:41:05+00:00","remoteAddr":"192.168.1.10","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEX-Pn5EXRqUxdkPY32OwAAAFI","level":3,"time":"2023-03-02T21:41:13+00:00","remoteAddr":"192.168.1.10","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEYE_n5EXRqUxdkPY32VwAAAEs","level":3,"time":"2023-03-02T21:41:39+00:00","remoteAddr":"192.168.1.10","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEYFvn5EXRqUxdkPY32WgAARgk","level":3,"time":"2023-03-02T21:41:43+00:00","remoteAddr":"192.168.1.114","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEZFtuWexLxU-7L4BbLWAAAQgA","level":3,"time":"2023-03-02T21:46:00+00:00","remoteAddr":"::1","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/notify_push/test/version","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"--","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEZb_YXktcXQfkJ2VCwXAAABAA","level":3,"time":"2023-03-02T21:47:28+00:00","remoteAddr":"::1","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/notify_push/test/version","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"--","version":"24.0.10.1","data":{"app":"PHP"}}
{"reqId":"ZAEZfvYXktcXQfkJ2VCwXQAABgA","level":3,"time":"2023-03-02T21:47:43+00:00","remoteAddr":"192.168.1.114","user":"--","app":"PHP","method":"GET","url":"/","message":"Declaration of OCA\\Talk\\Share\\RoomShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares): array must be compatible with OCP\\Share\\IShareProvider::getSharesInFolder($userId, OCP\\Files\\Folder $node, $reshares, $shallow = true) at /var/www/nextcloud/apps/spreed/lib/Share/RoomShareProvider.php#520","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:109.0) Gecko/20100101 Firefox/110.0","version":"24.0.10.1","data":{"app":"PHP"}}
