Nextcloud version: 20.0.14.2
Operating system and version / Apache or nginx version: : Not sure. Using shared hosting at bitpalast.net, very limited CLI accessibility.
PHP version: 7.4.25
Nextcloud service (including configuration pages) completely unavailable. Login not working. Entering anything results in an internal server error.
I suspect the reason for this is that I changed a configuration option. I activated “login by email”, but also use login credentials via SQL Backend. Did not configure the email backend before activating “login by email”.
Moreover I updated nextcloud today and then upped the PHP Version from 7.3.32 to 8.0.12, which made the service temporarily unavailable until I downgraded PHP to 7.4.25.
During the Nextcloud-update the web updater showed that it created a backup. Is this backup deleted after the update? I was unable to find it…
nextcloud.log shows this error which is an SQL Syntax Exception:
"Exception":"Doctrine\\DBAL\\Exception\\SyntaxErrorException","Message":"An exception occurred while executing 'SELECT u.ID AS uid, u.user_login AS username, u.user_login AS name, null AS email, null AS quota, null AS home, true AS active, false AS avatar, null AS salt, u.user_pass AS password FROM uCiCndcu_users u WHERE u.user_login = :username OR u. = :email ' with params [\"John Doe\", \"John Doe\"]:\n\nSQLSTATE[42000]: Syntax error or access violation: 1064 You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '= 'John Doe'' at line 1","Code":0,"Trace"
The error in particular is caused by the bit OR u. = :email
as far as I can tell.
config.php:
<php
'instanceid' => '<instanceid>',
'passwordsalt' => '<pw_salt>',
'secret' => '<secret>',
0 => '<URL>',
'datadirectory' => '/var/www/vhosts/<URL>/data',
'version' => '20.0.14.2',
'overwrite.cli.url' => 'https://<URL>',
'dbname' => 'db_cloud',
'dbhost' => 'localhost',
'dbuser' => 'cu_cloudadmin',
'dbpassword' => '<db_pw>',
'app_install_overwrite' =>
0 => 'user_sql',
1 => 'emlviewer',
'theme' => '',
'loglevel' => 2,
'updater.secret' => '<up_secret>',
unavailable due to above mentioned limitations
I was unable to find out exactly how to change the setting for the “login by mail”. Alternatively a change to the db, which I have full access to, can solve the syntax error also? Or editing the SQL Backend option via CLI to include the email field, which I can also easily include via the external DB, which I have access to.
I expect that the CLI limitations disallow me from performing the fix myself, but I want to provide my webspace provider with the exact command I wish to be executed.
Thankful for any help!
Taepper
