Hi I m newbie which like to learn and install nextcloud plus to my device
I got odroid hc2 with me
I have successfully install OMV with samba connection and so~on.
But i failed to get nextcloud running from my docker as my docker container kept on restarting… Been trying many way before i gave up.
Its ok.
Now i see there is a image here just to install it in odroid hc2.
Ended with. Tar. Bz2.
Download link :
NextCloudPi_OdroidHC2_09-29-18.tar.bz2
May i know what is the step to install this?
It seems i couldnt use etcher to flash it do sd card.
Is there any tutorial for a newbie like me around?
I browse around… I dont see what i need or i may not know my unit as arm/deb/arc/etc etc.
Hoping someone could point some direction for me to go.
Thank you.
Alex
Hi Guys,
Just fyi. Installation is not easy as ABC for newbie like me. LOL.
But i eventually managed to install this image with
Download image from captain #nachoparker
Unzip image using winrar.
Etcher/flash to sd card
Let it bootup run
(connect uart while booting)
It will promt for the login and pw which is root & 1233
Rename it immediately
U done for part #1
Run angryip scanner to scan your ip address for odroidxu4/hc2
Once you know what is the ip address
Paste it to the browser(i m using chrome here)
It will then bring you to activation page with ncp as a user name and long password 1 & 2 (save it into your note txt. U going to need this later)
Click on activate once you done
It will bring you to wizard
Follow the wizard
As i m totally noob.
I skip many steps which i m not known well of it. LOL
Till the end of the tab finished.
It will give you 2 option
1 is go to ncp administrator page
1 is go to ncp login page
You can chose any of them.
Ncp admin page. U need to use the user name and pw1 from the activation screen
Ncp login oage. U need to use the user name and pw2 from the activation screen
This is for part #2
Till here. U have a login pages(yourlocalIPaddress:80)and you have admin pages(yourlocalIPaddress:4443)
Hehehe.
Dont be scared… Googling around.
Puzzles around… Then u will managed to get this done.
