[SOLVED] https://sub.domain.org/nextcloud/index.php/login Not Found
example
longer
example
here
Nextcloud version (eg, 20.0.5): 25.0.3
Operating system and version (eg, Ubuntu 20.04): AlmaLinux 8.7
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.37 (AlmaLinux)
PHP version (eg, 7.4): PHP 7.4.30
I am self-hosting Nextcloud on a web server on my LAN. I have a separate server running Nginx Proxy Manager pointing at my web server. When accessing https://sub.domain.org/ it redirects to /nextcloud/index.php/login and gives an error:
Not Found
The requested URL was not found on this server.
However, on my LAN accessing http://ipaddress/nextcloud I am able to login with no issues.
The NPM configuration:
Details Tab:
Domain Names: sub.domain.org
Scheme: http
Forward: web_server_IP_address
Forward Port: 80
Custom locations Tab:
Scheme: http
Forward: web_server_IP_address/nextcloud/
Forward Port: 80
SSL Tab:
sub.domain.org certificate is selected. Force SSL is also selected
Is this the first time you’ve seen this error? (Y/N): Y (for the public domain name)
  1. enter https://sub.domain.org
PASTE HERE
  'instanceid' => 'x',
  'passwordsalt' => 'x',
  'secret' => 'x',
  'trusted_proxies' => ['NPM_IP_address'],
    0 => 'server_hostname',
    1 => 'server_IP_address',
    2 => 'sub.domain.org',
  'datadirectory' => '/path/to/data',
  'version' => '25.0.3.2',
  'overwrite.cli.url' => 'http://server_hostname/nextcloud',
  'dbname' => 'nextclouddb_name',
  'dbhost' => 'localhost',
  'dbuser' => 'nextclouddb_username',
  'dbpassword' => 'blahblah_Im_not_telling',
PASTE HERE
PASTE HERE
PASTE HERE
Anyone have any idea of the issue?
Playing around with all the entries for config.php I finally found the solution. I had to add this:
‘overwritewebroot’ => ‘/’
