Can i get some troubleshooting why loolwsd is not starting. I’ve read through other forum post but i cant seem to fix my own problem.
I’ve installed CODE on CentOS 7 not via Docker but as a separate package (followed the instruction on the official collabora site)
SELinux is disabled and firewalld as well.
I am using NGINX and PHP7.3
This is the message i get
● loolwsd.service - LibreOffice Online WebSocket Daemon Loaded: loaded (/usr/lib/systemd/system/loolwsd.service; enabled; vendor preset: disabled) Active: failed (Result: start-limit) since Tue 2019-02-12 15:05:12 UTC; 11min ago Process: 4858 ExecStart=/usr/bin/loolwsd --version --o:sys_template_path=/opt/lool/systemplate --o:child_root_path=/opt/lool/child-roots --o:file_server_root_path=/usr/share/loolwsd (code=exited, status=70) Main PID: 4858 (code=exited, status=70) Feb 12 15:05:12 shield systemd[1]: loolwsd.service: main process exited, code=exited, status=70/n/a Feb 12 15:05:12 shield systemd[1]: Unit loolwsd.service entered failed state. Feb 12 15:05:12 shield systemd[1]: loolwsd.service failed. Feb 12 15:05:12 shield systemd[1]: loolwsd.service holdoff time over, scheduling restart. Feb 12 15:05:12 shield systemd[1]: Stopped LibreOffice Online WebSocket Daemon. Feb 12 15:05:12 shield systemd[1]: start request repeated too quickly for loolwsd.service Feb 12 15:05:12 shield systemd[1]: Failed to start LibreOffice Online WebSocket Daemon. Feb 12 15:05:12 shield systemd[1]: Unit loolwsd.service entered failed state. Feb 12 15:05:12 shield systemd[1]: loolwsd.service failed.`
when I run journalctl -u loolwsd
, this is the last lines before crashing
Feb 12 15:05:09 shield loolwsd[4850]: wsd-04850-04850 2019-02-12 15:05:09.784325 [ loolwsd ] TRC Reading file: '/usr/share/loolwsd/loleaflet/dist/l10n/locore/ve.json as '/loleaflet/dist/l10n/locore/ve.json'| wsd/FileServer.cpp:476 Feb 12 15:05:09 shield loolwsd[4850]: wsd-04850-04850 2019-02-12 15:05:09.775504 [ loolwsd ] TRC Reading file: '/usr/share/loolwsd/loleaflet/dist/l10n/locore/ur.json as '/loleaflet/dist/l10n/locore/ur.json'| wsd/FileServer.cpp:476 Feb 12 15:05:09 shield loolwsd[4850]: wsd-04850-04850 2019-02-12 15:05:09.775583 [ loolwsd ] TRC Reading file: '/usr/share/loolwsd/loleaflet/dist/l10n/locore/hsb.json as '/loleaflet/dist/l10n/locore/hsb.json'| wsd/FileServer.cpp:476 Feb 12 15:05:09 shield loolwsd[4850]: wsd-04850-04850 2019-02-12 15:05:09.776722 [ loolwsd ] TRC Reading file: '/usr/share/loolwsd/loleaflet/dist/l10n/locore/ks.json as '/loleaflet/dist/l10n/locore/ks.json'| wsd/FileServer.cpp:476 Feb 12 15:05:09 shield loolwsd[4850]: wsd-04850-04850 2019-02-12 15:05:09.777101 [ loolwsd ] TRC Reading file: '/usr/share/loolwsd/loleaflet/dist/l10n/locore/hu-Hung.json as '/loleaflet/dist/l10n/locore/hu-Hung.json'| wsd/FileServer.cp Feb 12 15:05:09 shield loolwsd[4850]: wsd-04850-04850 2019-02-12 15:05:09.777159 [ loolwsd ] TRC Reading file: '/usr/share/loolwsd/loleaflet/dist/l10n/locore/uz.json as '/loleaflet/dist/l10n/locore/uz.json'| wsd/FileServer.cpp:476 Feb 12 15:05:09 shield loolwsd[4850]: wsd-04850-04850 2019-02-12 15:05:09.782785 [ loolwsd ] TRC Reading file: '/usr/share/loolwsd/loleaflet/dist/l10n/locore/hu.json as '/loleaflet/dist/l10n/locore/hu.json'| wsd/FileServer.cpp:476 Feb 12 15:05:09 shield loolwsd[4850]: wsd-04850-04850 2019-02-12 15:05:09.784325 [ loolwsd ] TRC Reading file: '/usr/share/loolwsd/loleaflet/dist/l10n/locore/ve.json as '/loleaflet/dist/l10n/locore/ve.json'| wsd/FileServer.cpp:476 Feb 12 15:05:09 shield loolwsd[4850]: wsd-04850-04850 2019-02-12 15:05:09.785081 [ loolwsd ] TRC Reading file: '/usr/share/loolwsd/loleaflet/dist/l10n/locore/id.json as '/loleaflet/dist/l10n/locore/id.json'| wsd/FileServer.cpp:476 Feb 12 15:05:09 shield loolwsd[4850]: wsd-04850-04850 2019-02-12 15:05:09.786156 [ loolwsd ] TRC Reading file: '/usr/share/loolwsd/loleaflet/dist/l10n/locore/vec.json as '/loleaflet/dist/l10n/locore/vec.json'| wsd/FileServer.cpp:476 Feb 12 15:05:09 shield systemd[1]: loolwsd.service: main process exited, code=exited, status=70/n/a Feb 12 15:05:09 shield systemd[1]: Unit loolwsd.service entered failed state. Feb 12 15:05:09 shield systemd[1]: loolwsd.service failed. Feb 12 15:05:10 shield systemd[1]: loolwsd.service holdoff time over, scheduling restart. Feb 12 15:05:10 shield systemd[1]: Stopped LibreOffice Online WebSocket Daemon. Feb 12 15:05:10 shield systemd[1]: Started LibreOffice Online WebSocket Daemon. Feb 12 15:05:10 shield systemd[1]: loolwsd.service: main process exited, code=exited, status=70/n/a Feb 12 15:05:10 shield systemd[1]: Unit loolwsd.service entered failed state. Feb 12 15:05:10 shield systemd[1]: loolwsd.service failed. Feb 12 15:05:10 shield systemd[1]: loolwsd.service holdoff time over, scheduling restart. Feb 12 15:05:10 shield systemd[1]: Stopped LibreOffice Online WebSocket Daemon. Feb 12 15:05:10 shield systemd[1]: Started LibreOffice Online WebSocket Daemon. Feb 12 15:05:11 shield systemd[1]: loolwsd.service: main process exited, code=exited, status=70/n/a Feb 12 15:05:11 shield systemd[1]: Unit loolwsd.service entered failed state. Feb 12 15:05:11 shield systemd[1]: loolwsd.service failed. Feb 12 15:05:11 shield systemd[1]: loolwsd.service holdoff time over, scheduling restart. Feb 12 15:05:11 shield systemd[1]: Stopped LibreOffice Online WebSocket Daemon. Feb 12 15:05:11 shield systemd[1]: Started LibreOffice Online WebSocket Daemon. Feb 12 15:05:12 shield systemd[1]: loolwsd.service: main process exited, code=exited, status=70/n/a Feb 12 15:05:12 shield systemd[1]: Unit loolwsd.service entered failed state.
