Hey,
I just set up a nextcloud (17.0.1) on Ubuntu 19.10 Server (Apache2, MariaDB, PHP7.3).
Unfortunately I can not get external storage support with SMB working. While entering the needed credentials I always get the red icon. smbclient and php-smbclient are installed.
Testing the SMB connetion via Commandline Interface is working. Testing with a small php-script I found in this forum ist working aswell. If I use the SMB-Connection Test-App the directory listing is empty.
The nextcloud Log is empty and does not list any SMB related Errors. If you need further information I will be happy to supply them. Thanks for your answers.
I added that definition parameter, restarted ubuntu and still get the same error as Cybersecfun.
icewind’s example.php composer test works fine as well as smbclient through terminal, but i’ve spent days on this and can’t get my windows server shares to mount
